6 members (Morganmike, CBY, Grumpy2, sewin, +8Rich, TBM), 312 guests, and 55 robots.
+8Rich 91
Luddite 50
Posts837,963
+ you'll soak up any errant water
Mark - No Longer driving
Posting Desperado
Posting Desperado
In the shower this m/ing and thought of you . NO I AM NOT . I forgot to turn it down and got the very hot in fact very hot water on me . Which brought to mind my bulkhead gets stonkingly hot on a long run since changed you can fry chips on it . Its the heat from the heater being so close .
Originally Posted By Fuel.inj
Thanks for the heads up. Just purchased a sheet of 2" thick open cell filter foam from the company below so I can cut to size.
http://www.aquariumonline.co.uk/
Originally Posted By sospan
I replaced the foam on mine with foam for aquarium pump filters. A very open cell foam. I got it from a pet place, trimmed it and stuck it on with double sided tape.
It was originally in block shape that I split to thinner section and these two bits covered the heater intake perfectly., butted the two together in the middle so no gaps. I bought a packet with a couple of foam blocks so have a spare for future replacement. They cost a couple of £ .
You need a closed cell foam for the seal otherwise you will get hot engine air coming in instead of fresh outside air. Not a problem in winter but in summer sunny
On my car there is a rubber seal blocking off the air intake area. It fills the gap up to the bonnet. The seal fits onto metal fittings similar to push on door/boot seals on tintops.
Some of the earlier cars have a much better arrangement.
My solution is here
