6 members (GrumpyPa, JohnHarris, James B W, +8Rich, thelastgizmo, Paulxj), 236 guests, and 40 robots.
+8Rich 94
John V6 49
Posts837,993
rockabilly john
#435512 10/03/17 09:30 AM
Does any forum member know of a supplier or where I can obtain some replacement self adhesive foam seal which sits on top of the heater box? The seal is approx 37 x 25mm and for a1994 plus 8.
Thanks in advance.
Posting Desperado
Posting Desperado
The motor accessory shop I use has rolls of two way sponge sticking tape they vary in width and length . You can stick it to the bulk head or the heater box ( and it sticks like like hell ) It has a green plastic film on one side if you want a none sticking side or you can remove the green tape from some and put it on the sticky side + it cuts easy with a small pair if scissors . If not you can pull it off and both sides stick . The roll has plenty on for around a fiver . You can also but it together if you need extra wide or thickness . I am going past the place this evening do you want me to pop in and get the name etc off the stuff and you can send away for some . I often use it for sticking plaques on the skimmed garage walls. swmbo informs me you can get it in HALFORDS .
Thanks for info. I'll look in Halfords first.
Posting Desperado
Posting Desperado
Ben Duncan done mine and lifted it up closer to the bulk head cleaned all the crap out that gets inside . Put a HOE Stainless Steel one in its place swmbo complains its now to hot .
Could try Woolies
They are a large online trim supplier that have lots a profiles in stock
I replaced the foam on mine with foam for aquarium pump filters. A very open cell foam. I got it from a pet place, trimmed it and stuck it on with double sided tape.
It was originally in block shape that I split to thinner section and these two bits covered the heater intake perfectly., butted the two together in the middle so no gaps. I bought a packet with a couple of foam blocks so have a spare for future replacement. They cost a couple of £ .
Try:
www.sealsdirect.co.uk
David 2001 4/4 4 seater
C.O.H Baines has a huge range.
Thanks for the heads up. Just purchased a sheet of 2" thick open cell filter foam from the company below so I can cut to size.
http://www.aquariumonline.co.uk/
You need a closed cell foam for the seal otherwise you will get hot engine air coming in instead of fresh outside air. Not a problem in winter but in summer sunny
