14 members (Bishmog, Andy, simon8201, riri, chanteclair, Mark+4, philandcolinsmor, +8Rich, JohnHarris, vincentvg, TBM, Haggispeed, Zach, Moggo),
278
38
Posts837,976
Posts: 939 Likes: 21
Posts: 939 Likes: 21 |
Does any forum member know of a supplier or where I can obtain some replacement self adhesive foam seal which sits on top of the heater box? The seal is approx 37 x 25mm and for a1994 plus 8. Thanks in advance.
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
The motor accessory shop I use has rolls of two way sponge sticking tape they vary in width and length . You can stick it to the bulk head or the heater box ( and it sticks like like hell ) It has a green plastic film on one side if you want a none sticking side or you can remove the green tape from some and put it on the sticky side + it cuts easy with a small pair if scissors . If not you can pull it off and both sides stick . The roll has plenty on for around a fiver . You can also but it together if you need extra wide or thickness . I am going past the place this evening do you want me to pop in and get the name etc off the stuff and you can send away for some . I often use it for sticking plaques on the skimmed garage walls.  informs me you can get it in HALFORDS .
Thanks for info. I'll look in Halfords first.
Ben Duncan done mine and lifted it up closer to the bulk head cleaned all the crap out that gets inside . Put a HOE Stainless Steel one in its place  complains its now to hot .
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Could try Woolies
They are a large online trim supplier that have lots a profiles in stock
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I replaced the foam on mine with foam for aquarium pump filters. A very open cell foam. I got it from a pet place, trimmed it and stuck it on with double sided tape. It was originally in block shape that I split to thinner section and these two bits covered the heater intake perfectly., butted the two together in the middle so no gaps. I bought a packet with a couple of foam blocks so have a spare for future replacement. They cost a couple of £ .
Posts: 184 |
Try: www.sealsdirect.co.ukDavid 2001 4/4 4 seater
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
C.O.H Baines has a huge range.
Thanks for the heads up. Just purchased a sheet of 2" thick open cell filter foam from the company below so I can cut to size. http://www.aquariumonline.co.uk/
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
I replaced the foam on mine with foam for aquarium pump filters. A very open cell foam. I got it from a pet place, trimmed it and stuck it on with double sided tape. It was originally in block shape that I split to thinner section and these two bits covered the heater intake perfectly., butted the two together in the middle so no gaps. I bought a packet with a couple of foam blocks so have a spare for future replacement. They cost a couple of £ . You need a closed cell foam for the seal otherwise you will get hot engine air coming in instead of fresh outside air. Not a problem in winter but in summer
