2 members (sprinty, TBM),
279
38
Posts837,992
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
+ you'll soak up any errant water
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
In the shower this m/ing and thought of you . NO I AM NOT . I forgot to turn it down and got the very hot in fact very hot water on me . Which brought to mind my bulkhead gets stonkingly hot on a long run since changed you can fry chips on it . Its the heat from the heater being so close .
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I replaced the foam on mine with foam for aquarium pump filters. A very open cell foam. I got it from a pet place, trimmed it and stuck it on with double sided tape. It was originally in block shape that I split to thinner section and these two bits covered the heater intake perfectly., butted the two together in the middle so no gaps. I bought a packet with a couple of foam blocks so have a spare for future replacement. They cost a couple of £ . You need a closed cell foam for the seal otherwise you will get hot engine air coming in instead of fresh outside air. Not a problem in winter but in summer On my car there is a rubber seal blocking off the air intake area. It fills the gap up to the bonnet. The seal fits onto metal fittings similar to push on door/boot seals on tintops.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Some of the earlier cars have a much better arrangement. My solution is here
