11 members (DMC1904, TomS, The Flitting, asterix, BLUE+4, mph, John07, Graham, G4FUJ, Grumpy2, DJC, Vansrv6),
321
44
Topics48,364
Posts813,336
Members9,215
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Dave, I also have a roller throttle pedal - could you photo-shop my scruffy carpets clean as well? Not from here................
Are the two holes over the clutch to let in air Roger? Are they not all like that then My Mog came with the same extra, to circulate air around my sweaty feet. Dave, do you need also a pic of the TBW roller throttle pedal? Thanks Heinz but I already have one on the GDI! (If you mean Throttle By Wire).
Like this Thank you for this Roger. is it OK to use in the book?
Posts: 26,759 Likes: 424
Posts: 26,759 Likes: 424 |
Are the two holes over the clutch to let in air Roger? Are they not all like that then My old cars weren't , must check the 2006 one.
Posts: 1,613 Likes: 22
Posts: 1,613 Likes: 22 |
Like this Thank you for this Roger. is it OK to use in the book? Dave, Yes you can use it.
Are the two holes over the clutch to let in air Roger? Are they not all like that then My old cars weren't , must check the 2006 one. Those 2 holes were actually the fixing holes for a remote brake fluid reservoir, I have since changed the master cylinder for a dual one which has an integral fluid reservoir. I never got around to filling the holes.
Posts: 90 |
Dave,
You seem to have enough replies, but since I have the floorboards and everything else out of the cockpit of my 58 +4 I can easily add to your collection. Will also do one of the roller in the 86 +4 which is certainly in better shape.
TomS
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
This thread has just reminded me to replace the wheels on my skate board
