7 members (Barkbark, Moggo, JMcL, Tony Quinn, +8Rich, TBM, BigLes),
295
Posts837,985
Posts: 180 |
Yes, H & S. I viewed the quality of their work & silencer & was reassured, & their reputation/reviews are excellent. They are expensive, but I wanted a high quality system. It will still be half the price of a Librands system. Infinity are cheaper & I think on a par with respect to quality, but they are a long way from both of us Ian
Posts: 1,948 |
Thanks guys, thinking about it.. it ticks over at such low revs when warmed up (about 600 if I recall) that I wonder if the idle can be adjusted. Yep - turn on your aircon! On mine (09 'Max) it resets the idle tickover to the cold-start value of 900ish. Presumably the ECU can sense the increased load of the compressor pump - I can't believe Morgan wired the aircon switch as an ECU input, but maybe the BMW loom does have this as standard?
Stuart "There's no skill substitute like cubic inches."
Posts: 844 |
The TR6 system is costing 3K!
Series 1 Aero 8
Posts: 263 |
Mine is booked in for Fri am for the "cut and shut" to remove the boxes under the running boards. I will record a before and after.
Ian
Aero-Ian
Aero 8 Series 1 Defender 90 BMW 330d M Touring
Posts: 180 |
All our Aeros are going to get a little wild - marvellous
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Thanks guys, thinking about it.. it ticks over at such low revs when warmed up (about 600 if I recall) that I wonder if the idle can be adjusted. Yep - turn on your aircon! On mine (09 'Max) it resets the idle tickover to the cold-start value of 900ish. Presumably the ECU can sense the increased load of the compressor pump - I can't believe Morgan wired the aircon switch as an ECU input, but maybe the BMW loom does have this as standard? Unfortunately on mine the idle barely moves when I turn it on, no more than 50/100 revs I suspect.
Aero 8 GTN #11
All our Aeros are going to get a little wild - marvellous Look forward to seeing some before/after pictures and maybe even sound bites
Aero 8 GTN #11
Posts: 336 |
There is a you tube of my aero with infinity system on cold start for comparison.
Posts: 263 |
What do we search for on you tube Mark?
Aero-Ian
Posts: 336 |
Aero 8 cold start did it for me, grey one in a garage. [video:youtube] http://youtu.be/3J0yzvuroMw[/video] On reflection it is still quiet in the vid, even with the rear boxes removed, but still loud enough on an open throttle and it burbles and pops on the overrun.....then silent when ideling. Perfect for me.
