5 members (flyfisher, sewin, jbk, Ricosan, Graham, G4FUJ), 337 guests, and 43 robots.
+8Rich 103
John V6 63
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,246
MossyfromNZ
Originally Posted By DaveW
So it's your fault then. And no IT was harmed during the process.
I've got to ask.............................
Did you have designer stubble?
No.....just one leg longer than the other?
Oops! It is stubble not stumble?
doh
Originally Posted By SpeedMog
I was working as principal electrical design engineer working on Jaguar Project XJ40.
Am I correct in thinking that you used thick film hybrids in the lighting circuits - may have been for bulb failure detection ?
Costock, UK
Disco 5
I didn't have designer stubble just a full set of beard in those days....and I DO have one leg longer than the other..so stumble is possible too...
Thick film hybrids.....hmmmm...can't exactly recall but something like that for current sensing for bulb failures would have been needed..
coffee
Phil Egginton
1979 4/4 4 seater
I vaguely remember visiting a thick film hybrid manufacturer and being told they were making stuff for XJ40. I was there to source a circuit for a PBX line card in my days as an electronics engineer (before I went over to the dark side in Marketing). Hybrids were a way of both achieving the density we needed (pre surface mount directly on to PCB) and the accuracy with trim to function resistors. It all seems so long ago.
Costock, UK
Disco 5
One of my front sidelights( inside the headlamp unit) failed. The bulb was ok. The problem was a corroded bullet connector. It was solid and couldn't be pulled apart.The wiring under the wing is quite exposed so no wonder it corroded. I cut the bullet connectors off and replaced them with spade ones and used shrink wrap to seal them. It was the nearside one so even more spraying from puddles that gather on the road side.
Bullet are fine when not exposed to the elements but surely waterproof connectors should be in the under wing area. The area gets a real dowsing from the wheels. The offside was in better condition so left for a while until I get round to replacement.
I sorted a rear fog problem last year that was caused by a multiplug coming apart ( behind the dash). No locktabs so a small cable tie was used to hold it together. The control module was also rattling. I had to open it and reglue the pcb inside back.
The trouble with Morgans is the random ( seems like that) changes to wiring that are hard to get info for. Gomog has some wiring diagrams but wire colours seem to change!
