1 members (RichardV6), 71 guests, and 16 robots.
+8Rich 102
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
Peter1062
Page 5 of 6 1 2 3 4 5 6
Originally Posted By Jays
On motorways at speed I prefer the roof up nowadays..
Not on our forthcoming trip to Isle of Man matey! It's side screens off all the way 😈
Sidescreens! Pffffff.... Wind up windows old boy! Next you'll be doing hand signals..
2008 4/4 1.8 Duratec
Ray Offline
Thats the trouble with a Healy, no sence of adventure. innocent
Formerly known as Aldermog
Surely it should be windscreens off and Aero Screens for the IOM????
SBM Offline
It's been spoken of, Peter..! Apparently a certain foot passenger will be disembarking at the island as three of us head home, so this MAY have had a bearing on the suggestion..!!!
innocent
Dave, does the seat belt have room to go under the screen and still run free?
Nicely finished though. Now, if it would fit into the side screen bag.....
2004 Silver Roadster S1
Rog Offline
Paul – This one won’t fit in a side screen bag but it will stand over the tunnel and stow away nicely behind the seats.
Roger
DaveW Offline OP
Yes there's no problem with the seatbelt.
Surely if you are careful what you chose to eat these are a bit unnecessary.
p.s. Don't ever pick up a veggy passenger though...
DaveW Offline OP
Post Photobucket reboot from October 2009.
This task began after my recent trip to Curborough with MrsW, who felt that it was a bit draughty on the A38. It got me wondering about a conventional mesh Windstop. I'd seen one on a Mog at Curborough and it was mounted low, just above the head restraints. Once home, I looked on "a Mog website" and was surprised to see that they come in at well over Β£200, spend and the picture showed it installed quite high. This also requires drilling the inner wing wood to fix.
For a while in Miscellany, there used to be a perspex windstop which fastened to the head restraints with elasticated cords, but I believe this is no longer made. I must admit that I'm not keen on the elasticated solution, but it got me thinking about a perspex shield and a no-drill solution.
First I sourced the Perspex, and in doing so also produced the spare wheel filler which turned out to be a really simple fix.
I had to take a view on the measurements of the windstop, since I was starting from scratch, and this is how the perspex looked when it arrived, complete with protective film both sides.
This image not available.
My first thoughts were to fasten around the head restraint stalks, so I obtained some U bolts which I covered in plastic sleeving. The main disadvantage to this method is that both seats need to be kept level.
Had this worked, it would have been so simple to mass produce. But the U bolts were not long enough. I tried extending but the method of location was too floppy, and the windstop flopped rearwards at 45degrees. So 'Plan A' failed.
Time for a rethink.
I needed a bracket that would locate around the head restraint stalk but that would be non-damaging. I eventually hit on the idea of a perspex bracket. For this I made use of an old number plate by stripping off the backing and cleaning up the plastic. It's a bit rough & ready, but this is a prototype after all.............
This is how the brackets looked after I'd been at them with the Dremel.........
I would have liked to avoid working with stainless steel once again, but anything less would not have looked right. My first pair of angle brackets were scrap. You live & learn. I took a lot more time with the second pair. These are not 100% but are good enough for me..........
Next I added a thin U channel of neoprene - the same profile as used on various other projects. This gives a snug fit around the stalks.....
This is one fitted to the windstop - using stainless dome bolts.
This is how it fits. Note that the fasteners are clear of the leather. At the end of this process I had to add a 1/4 inch strip of neoprene as a spacer between the stalk and the bracket to add a small amount of 'lift'.
More to follow..............................
DaveW Offline OP
Post Photobucket reboot from October 2009 continued..........
So after a bit of tweaking to get the angle of the brackets right, this is how it looks from the rear:
Close up:
You'll see that I've slotted two lengths of clear tube where the seatbelts pass under the windstop. I don't think they will rub, it's just a precaution..........
It's almost invisible when fitted........
So all I need to do now is road test it, but not today.
I'll report back if it makes any difference.
More to follow >>>>>>>>>>>>>>>>>>>>>>>>>>>>
