1 members (New Zealand), 129 guests, and 16 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
AlexCreasey
Page 5 of 6 1 2 3 4 5 6
vMog #439685 29/03/17 06:25 PM
Black Rat
Black Rat
Originally Posted By vMog
Hello,
Has anyone yet tried tyres with the following dimensions ?
195/65 15...
Main question is : ok I get 1cm and the speedometer gets cheated 3.5%, but is there any other catch???
Cheers,
Vladimir
I run 185/70/15 plenty clearance, speedo reads a bit slow.
Keith
2013 narrow bodied + 4 Ruby.
I am running 195/65 R15 Michelin CrossClimate tyres. We have to have winter certified tyres or chains on board where I live from 15 November to 15 April, The CrossClimate work very well for me.
As others have said the speedo is more accurate but adjusting the calibration is very easy.
DaveW #439914 30/03/17 05:22 PM
Thanks everyone for the tips and lessons learned!
I will go for these then, and Michelin CrossClimate.
Cheers,
Vladimir
vMog is a 2013 +4/ 4 seater, dark red with saddle brown trim, wooden dashboard and console.
vMog #440046 31/03/17 08:22 AM
Cheers,
Vladimir
Great grip in the wet. You may have to play with tyre pressures a bit. I run 1.7 bar. 1.6 is ok in the front. 1.5 bar, the Morgan recommended pressure, seems a bit soft to me.
Also worth mentioning that mine feel better now that I have a few thousand Km on them. They now have the CrossClimate Plus which is probably an improvement on the ones I have.
DaveW #440186 31/03/17 09:00 PM
Thanks Peter!
DaveW #440549 02/04/17 09:53 PM
So I am thoroughly confused....
What should a 2011 Plus 4 be running? Mine has I believe the original factory fitted tyres... which are avon 205/65 r15. When I look at a tyre company's website based on my reg it says they should be 195/65 r15. The handbook supplied is for a later car... it has 4 tyre sizes none of which is what is fitted...
It depends what rim width you are running. I believe that +4 rims are 5.5" - in which case the tyres should theoretically be 185s or 195s. If you have 6" rims then 205s would be ok, but would probably make the car feel pretty ponderous to drive. On a 5.5" rim they'd be a bit too much and I wouldn't recommend replacing with the same size.
If you have 5.5" rims, and you would like your car to feel more nimble and agile, then I would go to 185, or 195s if you prefer a more 'planted' feel. Either would cope perfectly with the power output of a +4.
DaveW #440584 03/04/17 07:02 AM
Thanks Tim
DaveW #440603 03/04/17 08:41 AM
http://www.carbibles.com/tyre_bible.html
Is a very handy reference site - there is no one size specific for a wheel but a range of sizes.
Have a good read through it.
Mark - No Longer driving
Black Rat
Black Rat
I would say the tyres already fitted are the right ones. 185 are for narrow bodied +4.
Most +4 have the 205.
Keith
