7 members (sewin, Jensen1960, RichB, gomog, JMcL, Rastus, hugo),
186
Posts837,998
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Either glue or DST down the A post John. The seal may need trimming to length.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
On mine it just slips over the blade like side piller of the windscreen, no glue, no stick.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Try woolies. www.woolies-trim.co.ukThey supply a range of seals. Another one is carbuilder solutions......www.carbuildersolutions.com
Posts: 23 |
Allan 2005 Roadster
Posts: 23 |
Allan 2005 Roadster
Posts: 23 |
Allan 2005 Roadster
Posts: 23 |
Do you know where to purchase
Allan 2005 Roadster
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Either glue or DST down the A post John. The seal may need trimming to length. The new widescreen rubber seals come already fitted with double-sided tape, you just peel off the packing and stick them in place. At least, the pair I bought from Williams came like this.
Do you know where to purchase Any Morgan dealer ought to be able to get them for you, I got a pair from Williams. Easiest is probably to give Melvyn Rutter a call, he carries an enormous stock of spares.
Posts: 27,836 Likes: 763
Posts: 27,836 Likes: 763 |
I also used glue as the sticky back wasn't so good. Will try to post a picture when I have the car out to visit Bicester on Sun.
