9 members (Chris Cosher, Ian Wegg, Montegue, mph, Grumpy2, How, +8Rich, John V6, RichardV6),
212
66
Posts837,934
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
I suspect you mean intarsia pattern socks and sweaters. Pringles made some truly startling patterned sweaters, particularly the Nick Faldo range, I had one but have destroyed any photos. However they also made some really nice plain sweaters, I wish I could get another navy crew neck with a discreet logo.
That would go very well with my new pink check golf trousers.
SFG 2012 4/4 Sport
Posts: 2,568 Likes: 98
Posts: 2,568 Likes: 98 |
Taking a different route of tyre changes - I took our 2000 4/4 4 Seater on SS wires in for a new set of boots. Off came Yokohama C-Drive 2 in 195/60/15 and on went Toyo R888R's iMedium compound in195/55/15.
The drive characteristics were like night and day.... the stiffer sidewall of the Toyo's giving much more communication of what's going on without it being harsh - I found the Yoko's squidgy and the a bit bouncy at times. The tyre doing the work of the suspension and not in a good way.
Drove from High Wycombe to Liverpool and am very pleased with the swap. I might consider putting a 205/55 version on the rear to slightly up-tyre the back end to the original rolling radius - but that's just fiddling.
Posts: 22,369 Likes: 354
Posts: 22,369 Likes: 354 |
I did once have a yellow Paisley pattern shirt with matching tie. The tie could have been cut from the back. It was remarkable.
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
Dave
Don't believe you...if no picture it is not true !!!!
Hee hee
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Drove from High Wycombe to Liverpool and am very pleased with the swap. I might consider putting a 205/55 version on the rear to slightly up-tyre the back end to the original rolling radius - but that's just fiddling. I can well imagine that it would be a great improvement on a good road. The roll centre would be lowered too. It would be a disaster for me however; speed humps, and even getting in to my garage, were difficult enough with the standard 195/60 and that is why I went 195/65 15 which raise it 1cm. To drop down a centimetre with the 195/55 would be great on my favourite twisties but I wouldn't be able to traverse some towns or get back in to my garage without tremendous scrapes on the cross member under the gearbox.
