7 members (RedThree, Davetherave, Grumpy2, Craig Jezz, Aeromax51, Socalm3w, Gambalunga), 256 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,145
Page 1 of 4 1 2 3 4
#450343 21/05/17 06:16 PM
Georgie Offline OP
Cleaning the car yesterday for the Steam & Classics rally at Haverstreet Station when I discovered:
A 35mm crack on the offside wing inboard of the side light, seems to be in line with the edge of the aluminium pad welded on the underside to take the wingstay
According to Gomog this seems to be a common problem.
http://www.gomog.com/allmorgan/superformwingpainting.html#BUBBLING
First priority is to stop the crack spreading any further, I cleaned the car just two weeks ago and didn't see any signs of a crack then, since I have only driver around the island on short runs so it has developed quickly.
Any advice at this stage before I do anything would be greatly appreciated.
David
2001 4/4 4 seater
Cracks can be halted by drilling a small hole at the end/ends of the crack. Are you sure it's a superform wing though? In 2001 it's more likely to be a fabricated wing.
Martin (Deano)
Georgie Offline OP
Hi Deano
Thanks, just to clarify according to Charles Morgan & Bowden 'Morgan 100 years' The four seater was the first model after the +8 to be fitted with the superform wings, this was in 1999.
David
Superform wings were introduced around 1997. I've not seen a crack there before. The place they can crack is the filler over the welding of the headlight nacelle where there have been a few incidents.
I stand corrected. In my head the superform process was first used on the aero platform. Thanks Jays & David.
Martin (Deano)
See my post "new cars with cracks in the headlight cowls" on this forum
I suggest that you check that the wing stay is not loose or broken.
Are you absolutely sure you haven't suffered a stone flinging up under the arch deform the wing? And therefore crack the paint?
Mark - No Longer driving
Georgie Offline OP
Hi John, Mark
Thanks for the comments.
Everything is very secure underneath, and no apparent damage from flying debris.
Will investigate further today, but I think the priority is to drill the holes to stop any further cracking.
David
My Plus 4 was one of the cars that had the problem with cracking along the joint between the wing and headlight cowl. It was the joint that cracked and not the aluminium.
From the photograph this looks more like either a fatigue crack or an impact crack. I think I would investigate if this is in the metal or is just the paint before I drilled any holes.
Page 1 of 4 1 2 3 4
