0 members (), 231 guests, and 43 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,148
Georgetoad, woolfie
Page 2 of 4 1 2 3 4
I was going to suggest the same.
Originally Posted By Scrambledsignals
My Plus 4 was one of the cars that had the problem with cracking along the joint between the wing and headlight cowl. It was the joint that cracked and not the aluminium.
From the photograph this looks more like either a fatigue crack or an impact crack. I think I would investigate if this is in the metal or is just the paint before I drilled any holes.
This does look like a different issue.
Hope it's sorted soon
Black Rat
Black Rat
I had the cracked wings too, it was because the headlights were bonded and not welded. This is a completely different issue.
Keith
2013 narrow bodied + 4 Ruby.
Georgie Offline OP
Thanks Scambledsignals and Graham
Have been distracted for a few days but I will rub down the paint and see what is going on.
David
You could consider, although some what retrospective, fitting as i have, a rubber mount between the hefty front wing stay and the wing. I used what halfords call a mini exhaust mount, its a 1" rubber bobbin, it may absorb some of the vibration induced stress.
Georgie Offline OP
Hi Lowflyer
Have removed the wing stay and wondered why there is no shock absorption, except a thin rubber?
Started rubbing down with 240grit thinking I would hit aluminium quickly but no, had to gouge out 2.5mm of filler but luckily no crack in the superform, see photo
Can anybody recommend a good 2 pot filler for this type of repair?
David 2001 4/4 4 seater
Great news David that it isn't the ali that's cracked
In many ways a result!
Good news that it's an easy fix but unusual to have so much filler on a superform wing.
Martin (Deano)
Thats a mountain of filler - must be a reason to have used that much?
Page 2 of 4 1 2 3 4
