Posts837,998
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
I do like the steering wheel. I really must look into getting one of those in the Coupe.
Posts: 82 |
You seem to have gotten my name on the licence plate....
Some element have crossed my mind for you to look out for.
Alignment and water sealing of the front edge of the door can be a little marginal and so it is worth checking. It is the vertical leading edge that tends to allow water in so a low pressure of water (hose not pressure washer) will pick this up. Ditto the sealing around the windscreen.
The windscreen wipers rest in the wrong place and either shred themselves on the windscreen surround or wear the paint.
I love the interior finish but white will need some love. The aero might well drag dirt into the cabin if it is similar to the Series 2 so I would look into protecting/cleaning it regularly.
Make certain you take your neighbours for a run in it so they love it. Then the noise you make coming home with those sidepipes will be somewhat offset.
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
- Protective film on the front of the car - Glovebox cover
But, most of all, CONGRATS!!!!!!!!!!!
Posts: 5,587 |
LED headlamps , Wolf clocks ?
Posts: 3,841 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,841 Likes: 11 |
But, most of all, CONGRATS!!!!!!!!!!! I'd also get the centre consol under the handbrake lever done and also the rear wings. You'll spend a lot of time leaning over the car if you use the boot a stud on a pair of jeans will spoil your day.
Slowly going green
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
That looks lovely, enjoy!
Aero 8 GTN #11
Posts: 7,363 |
But, most of all, CONGRATS!!!!!!!!!!! I'd also get the centre consol under the handbrake lever done and also the rear wings. You'll spend a lot of time leaning over the car if you use the boot a stud on a pair of jeans will spoil your day. ClearPlex on the windscreen too! Super looking car Richard, enjoy...
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 8,646 |
I'd not heard of clearplex; now I've googled it. Is it effective ?
Giles. Mogless in Paris.
Posts: 7,363 |
Very effective - I have it on one of our cars, wish I'd known about it for the Plus 8 which has a badly micro-scarred windscreen and it's not a standard size! ClearPlex linky
Brian
