9 members (bmgermany, MOG42, Strathaven, Clipper, JoeSpeetjens, gomog, MJF, RichardV6, John Winn),
270
33
Topics49,911
Posts838,146
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
I was going to suggest the same.
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
My Plus 4 was one of the cars that had the problem with cracking along the joint between the wing and headlight cowl. It was the joint that cracked and not the aluminium.
From the photograph this looks more like either a fatigue crack or an impact crack. I think I would investigate if this is in the metal or is just the paint before I drilled any holes. This does look like a different issue. Hope it's sorted soon
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
From the photograph this looks more like either a fatigue crack or an impact crack. I think I would investigate if this is in the metal or is just the paint before I drilled any holes. This does look like a different issue. Hope it's sorted soon I had the cracked wings too, it was because the headlights were bonded and not welded. This is a completely different issue.
Posts: 184 |
Thanks Scambledsignals and Graham My Plus 4 was one of the cars that had the problem with cracking along the joint between the wing and headlight cowl. It was the joint that cracked and not the aluminium.
From the photograph this looks more like either a fatigue crack or an impact crack. I think I would investigate if this is in the metal or is just the paint before I drilled any holes. Have been distracted for a few days but I will rub down the paint and see what is going on. David
Posts: 327 |
You could consider, although some what retrospective, fitting as i have, a rubber mount between the hefty front wing stay and the wing. I used what halfords call a mini exhaust mount, its a 1" rubber bobbin, it may absorb some of the vibration induced stress.
Posts: 184 |
Hi Lowflyer You could consider, although some what retrospective, fitting as i have, a rubber mount between the hefty front wing stay and the wing. I used what halfords call a mini exhaust mount, its a 1" rubber bobbin, it may absorb some of the vibration induced stress. Have removed the wing stay and wondered why there is no shock absorption, except a thin rubber? Started rubbing down with 240grit thinking I would hit aluminium quickly but no, had to gouge out 2.5mm of filler but luckily no crack in the superform, see photo  Can anybody recommend a good 2 pot filler for this type of repair? David 2001 4/4 4 seater
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Great news David that it isn't the ali that's cracked
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
Good news that it's an easy fix but unusual to have so much filler on a superform wing.
Martin (Deano)
Posts: 431 |
Thats a mountain of filler - must be a reason to have used that much?
