2 members (John Winn, Gordon D),
261
Posts837,997
Posts: 3,841 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,841 Likes: 11 |
Brian any idea of costs? Might be worth looking at for the work fleet we seem to have a new screen every other week.
Slowly going green
Posts: 7,363 |
The local Reep branch (agents for ClearPlex) usually start with £300-350 per screen depending on the size, let me just say this figure is very much negotiable!
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 844 |
Bromley quoted £195+vat for an Aero screen
Series 1 Aero 8
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Posts: 101 Likes: 1
Posts: 101 Likes: 1 |
You seem to have gotten my name on the licence plate.... I had to have it to go with...
RH03MOG.com Adventures of a Morgan 3-wheeler.
Posts: 101 Likes: 1
Some element have crossed my mind for you to look out for.
Alignment and water sealing of the front edge of the door can be a little marginal and so it is worth checking. It is the vertical leading edge that tends to allow water in so a low pressure of water (hose not pressure washer) will pick this up. Ditto the sealing around the windscreen.
The windscreen wipers rest in the wrong place and either shred themselves on the windscreen surround or wear the paint.
I love the interior finish but white will need some love. The aero might well drag dirt into the cabin if it is similar to the Series 2 so I would look into protecting/cleaning it regularly.
Make certain you take your neighbours for a run in it so they love it. Then the noise you make coming home with those sidepipes will be somewhat offset. Alistair Thanks for the advice. It appears to be pretty watertight so far. I deliberately drove the car in heavy rain and no problems - touch wood.
Posts: 101 Likes: 1
- Protective film on the front of the car - Glovebox cover
But, most of all, CONGRATS!!!!!!!!!!! Glovebox cover? Is there something available or is this a case of making something to suit?
Posts: 101 Likes: 1
Very effective - I have it on one of our cars, wish I'd known about it for the Plus 8 which has a badly micro-scarred windscreen and it's not a standard size! ClearPlex linky Now that also looks worth investigating further. Thanks Aeroman.
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
Glovebox cover? Is there something available or is this a case of making something to suit? Borghi (Morgan importer for Italy) did it for me.
