1 members (TalkMorgan),
370
102
Topics49,880
Posts837,760
Posts: 853 |
The fish can't swim anywhere.....
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
Except that it is impossible to get electricity from your house into the grid. That's why there's been no hurry to meter it and that's why the payments are "deemed to be 50%" of your panel's output. Any electricity actually going beyond your meter is lost in heat at the first substation it meets. All helps global warming....... Nick I'm afraid you are misusing the term "grid". It's true that solar-generated power isn't transformed back up to the high voltages used on the Transmission network, but it's not accurate to say it's not available on the grid. All the homes downstream of the substation will be able to make use of any local generation, and it all acts to reduce load (and therefore generation requirements) on the grid as a whole. Remember that although different parts of the National Grid operate at different voltages, it all operates at the same frequency. Extra load on the network causes the frequency to drop, excess generation causes it to rise. This effect will happen across the entire network simultaneously, regardless of the voltage or where the load or generation is occurring. There are many mechanisms that the National Grid Company uses to balance generation and demand on the system, and various levels of response time involved. For example, some industries have special contracts which mean they have special kit installed in their supplies to drop power with sub-second response to help balance the grid. All solar power generation is a useful resource, it reduces the need for fossil generation, and with the rapid growth of battery storage, it offers a real opportunity for small generators to participate in the market - which is potentially very lucrative. On September 14th last year at 12:00 (Noon), the spot price for electricity went from the base price of £100/MWh to over £1500/MWh. There's loads of companies putting together mechanisms to aggregate micro generators into tradeable blocks. We had this discussion before I remember. How many houses to a substation? What if, as is ideal, they all have solar panels fitted? And more....my basic point that the "deemed" generation is totally theoretical isn't it? That's why the latest solar farms are geared and positioned for supplying a (for instance) single office block, e.g. the Bristol council offices and that the industry is moving away from the concept of solar power entering the grid. You say I'm misusing the term grid, but I say you are. Domestic solar panels don't bolster the grid in any other way than reducing demand whilst they are working. Which is excellent in itself but the concept of paying consumers for a theoretical input to the grid is nonsense. Even supplying the next door house is theoretical you must admit that. Nick
Posts: 4,654 Likes: 124
Posts: 4,654 Likes: 124 |
Ken,
I consider Smart Meters are, at the moment, pointless.
Why?
Certainly they are of benefit to the supply company, as they remove the need for a meter reader...but it is unclear if, should you change supplier, if the new supplier can access the smart meter. So until Smart Meters are "universal" they only help discourage change.
All the other reasons touted by the supply company are spurious. I really don't need to know, moment by moment, how much power I'm using. The meters don't in my view, provide data that facilitates sensible management of consumption. We use the power we need, we have LED lights almost everywhere and we mostly turn off devices we are not using.
I will decline a smart meter if and when offered: Sorry to say Peter you are 100% wrong in this regard. Have a look at the 'Faster switching' initiative and how the DCC uses the smart technology to make it easier, not harder to change supplier. If you're not interested in optimising your energy usage then a Smart meter is probably not for you, but you'll end up paying more for your power. It's true that Smart meters reduce the measuring and billing costs for suppliers, and they will be able to reflect that in their tariffs. Customers who choose not to take advantage of the technology will naturally not be able to benefit from the reduced rate tariffs. There are lots of companies out there developing smart apps which use a combination of appliance databases and smart data to give a live view of your energy consumption at 15-second granularity. Current pilots are using standard appliance profiles, the next generation will know the specific consumption profiles of particular models, so you'll be able to see how much an AEG 123 will compare to a Zanussi XYZ for your particular usage pattern. KenA: for your particular requirement, I would think a monitoring plug as Alistair and others have already suggested would be the way to go. If you want to get really technical about measuring the true consumption of appliance, you'll need to read up on Power Factors. Devices like Fridges and Freezers quite often take power out of phase with voltage, meaning they appear to use more power than they actually do. Simple monitors are unable to measure this so they don't give a totally accurate view. We had a smart meter fitted and it was interesting to see the usage monitor for a few weeks but basically we use what we need and try to minimise wastage. The meter display became boring and pointless and ended up in a drawer. Then we switched from Eon to Robin Hood who immediately raised their prices and can't utilise the Eon smart meter wireless readings, so I am back to taking manual readings. What a waste of money.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
Bob, the key words are "in future". There is nothing in place for the SM to monitor the export at present. I didn't actually read "in the future" in the paragraph I was referring to. I read "in due course". However, not wanting to appear as nit picking, all I said was hold off moving to a smart meter as long as possible.
Posts: 28,906 Likes: 353
Posts: 28,906 Likes: 353 |
...hold off moving to a smart meter as long as possible... Exactly my plan. There has been an interesting article or two in the IET journal. There is one in the present edition which I haven't yet read...
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
Were you charged for your Smart meter installation? That sounds a bit dodgy to start with - unless you went for a special installation for some reason. But yes, until all the suppliers get up to speed with handling the Smart data technology, which uses an entirely different data network and set of protocols, then switching to another supplier will always carry risk of ending up with a numpty that doesn't have decent systems. A lot of the small entry-level suppliers rely on avoiding the higher costs of having larger numbers of customers, and run all their metering and billing on simple 'out-of-the-box' solutions such as supplied by Utilisoft. As a result, they can offer cheaper headline rates. The downside is that they generally lack a deep understanding of the wholesale market, have poor hedging strategies, and are unable to withstand market price movements with the resilience of the more mature providers. It might not seem like it, but when you sign an electricity supply contract, it's not really the electrons that come out of our wall sockets that you're paying for. You're effectively buying two additional things - an ability to calculate your true consumption and provide you with an accurate bill, and a wholesale cost management service to insulate you from swings in wholesale markets. The Big Six suppliers spend a lot of time and money modelling future energy demand and supply capacity, and using that information to hedge their positions to be able to provide predictable prices for their customers. That's generally why they cost more but are able to offer longer fixed-price contracts. They are also generally better at handling complaints - but I suppose one could argue that this is because they are more used to receiving them  Other suppliers, like Ecotricity, don't try to compete on price. Instead they have simple variable tariffs which track the market and pump the extra money into more renewables generation and storage. Still others, like GB Energy, try to build market share by offering rock-bottom prices and avoiding investment in hedging and capacity management. They go bust.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Tim,
interesting and informative...but I stand by my view that Smart Meters are primarily to benefit the utility supplier.
As others have said the display is amusing/interesting for a while, but like the "Smart Meter" I have on the SMA Inverter and the "Smart Power Monitor" (it has an inductive coupler on the main power feed to measure how much power I'm using) EON gave me about 6 years ago in the end they are just numbers.
In the same vein, in my view, is the "Hive" controller that British Gas are pushing, which allows one to control heating and stuff from a smart phone, it is not actually very helpful. I researched the smart heating controllers and concluded that for a large, mostly brick and concrete, very well insulated 1980s house the most efficient way to heat it is to use the CH to maintain a steady state at about 18C. The CH is on from 0600 to 21:00 when it is on. We then use local heating to raise temperature as needed: the AGA in the kitchen and log burner in the living room.....or we put on a pullover....
Tim,
Peter, Our Nest remote controlling application allows my wife who has MS to up or down the heat when she needs to without the trouble of having to go to the boiler itself. I'll admit this is a particular case, though.
Posts: 3,700 Likes: 131
Posts: 3,700 Likes: 131 |
Having just received my latest bill from British Gas I have to admit that my initial enthusiasm for smart meters is on the wane...  Short of building my own blast furnace I'm not sure how I could have used one and half grands worth of gas in less than 8 weeks... but apparently they forecast I would!
Tim,
Peter, Our Nest remote controlling application allows my wife who has MS to up or down the heat when she needs to without the trouble of having to go to the boiler itself. I'll admit this is a particular case, though. Bob, in our house the lag time between turning up the thermostat and any noticeable increase in room temperature is about 1 hour, likewise turning it down has a very slow heat reduction effect. I'm curious: how old is your home and what is the internal construction? All the internal walls here are concrete block, so lots of mass. The walls are insulated and on the N and E aspects there is clay tile hanging over insulation felt as well.
