Topics49,921
Posts838,290
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Thought this might be of interest to other suffers. Whilst my bonnet halves are firmly pulled down by the spring catches the top hinge has always been a bit too free and lose. It would rattles clatter and crash whilst driving around. I don’t know if they are all like this but I do surmise that this may be one reason why the front suspension gets so much bad press. But now I’ve sorted it and what a transformation. Even to the point that I have been driving around smugly aiming at the pot holes just to savour the silence A very simple fix. A couple of meters of this stuff . One meter attached to each bonnet and four little 1/8” thick hard rubber pads bonded to the hinges. I’ve had the pads on for a while but have just added the edging and it has made a significant difference to my car. Little rubber pad bonded on - 4 positions
Roger 2011 Plus 4
Posts: 22,375 Likes: 354
Posts: 22,375 Likes: 354 |
A good tip Roger. I've not had hinge rattle but I've always used pads at all four corners of each bonnet. Keep a watch on the pads because over mileage some of them squirm out of position.
Posts: 12,270 Likes: 325
Posts: 12,270 Likes: 325 |
Nice fix, I had a similar problem, and solved it by making pads from Sugru.
I degreased the cowl so that it would stick to it, and put a smear of vaseline on the bonnet face to prevent. Then I simply shut the bonnet onto the soft Sugru and left it to go off, resulting in two formed pads which stop the rattling.
Posts: 3,831 Likes: 69
Posts: 3,831 Likes: 69 |
I degreased the cowl so that it would stick to it, and put a smear of vaseline on the bonnet face to prevent. Then I simply shut the bonnet onto the soft Sugru and left it to go off, resulting in two formed pads which stop the rattling. That's clever, I like that.
What is this magic thing Sugru?
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
What is this magic thing Sugru? It's witchcraft, Dave. Mouldable glue that turns to rubber when set according to the High Lord Google.. Crazy!
What is this magic thing Sugru? It's witchcraft, Dave. Mouldable glue that turns to rubber when set according to the High Lord Google.. Crazy! Marvellous stuff, I use it for all sorts of fixes. Highly recommended.
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
Sugru is great. Different colours too.
It's even for sale in Halfords, it seems. I'm becoming a believer.. Sugru
Posts: 14,751 Likes: 158
Posts: 14,751 Likes: 158 |
I use some little squares of self adhesive neoprene. Love the cold air intake
