1 members (Alan Patterson),
210
Posts837,998
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
Hmmmm.. Guesses 1. Peter has gone green and was being economical. 2. Pedal travel limited by new floor/pedal assembly. 3. He's teasing us and only got 10 laps out of it before it ran empty. Reputation intact....
Posts: 431 |
Not sure it's a good sign that the tyres did not get hot. My guess is that if it did start to lose traction you would be facing the other way in the blink of an eyelid. To me that suggests you were either tootling along or the tyres a made of plastic.
The crz66 I have get very hot even with just spirited road use.
Posts: 4,896 |
Even after a quick run when I got back to the paddock the rear tyres were not even hand hot and not really soft. So obviously I wasn't stressing the car. Didn't use much fuel, either. About 15L for 50 laps, or 95 miles. So 28mpg..normal road use.... Don't believe it, unless you were ambling around at 70mph, and have lost the plot!
Adrian
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
Even after a quick run when I got back to the paddock the rear tyres were not even hand hot and not really soft. So obviously I wasn't stressing the car. Didn't use much fuel, either. About 15L for 50 laps, or 95 miles. So 28mpg..normal road use.... Don't believe it, unless you were ambling around at 70mph, and have lost the plot! Sunday afternoon drive! Surely not.
Martin (Deano)
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Tyres... 2012 Dated Avon ZZ3....
15 min sessions with 7 cars on track Speed..well the Caterham boys were very quick, a couple lapped me. The Works Caterham with their demmo driver lapped me twice.
Otherwise I kept my place amongst the 4/4s.
Overtaken by a Brooklands Roadster and some +4s.
Remember, this was the first track day I've done and I only did the morning session, due to the mechanical issue.
Not to mention the cost and pain of sticking something as fine as the Aero into the Kitty-litter. I still have nightmares of the noise it makes as you go into it. On the soft bodywork of a mog I fear to think of the mess it would make.
Key thing is that you enjoyed the experience
Martin (Deano)
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Only just caught this- hope it's fixed quickly...
+8 4.8
Posts: 272 |
Peter I gather you were at the Castle Coombe track. I remember it as a bumpy little beast with high speeds. As a matter of interest how did the suspension handle the bumps. Given its pedigree I would expect it was a good surprise ? Bumps..what bumps? Seriously, it was amazing and with more track knowledge and more "balls" it would have been massively fast. I left the car in Sport Auto... most of the time it was in 2nd or 3rd, with 4th on the long straight past the pits and into Quarry. The brakes just laughed at the work they were doing...I was braking later than all of the trads, yet taking the corner slower, then losing them as I pulled away. My problem is that I don't know how the car feels at the limit and don't have the balls to explore. With Charles in his 4/4 on Quarry the car was starting to drift at about 60, Tarka was on rails at 50 at the same place. So how fast would I need to have been going to get the car to drift? So, I suppose I need to go out in a Plus 8 with someone who can demonstrate, but I'm not sure if my neck would take the lateral G. Further evidence of lack of effort... After 50 or so laps there was no obvious wear on the tyres: contrast with Charles' 4/4 rear tyres showed clear evidence of wear and the surface was hot and sticky. Even after a quick run when I got back to the paddock the rear tyres were not even hand hot and not really soft. So obviously I wasn't stressing the car. Didn't use much fuel, either. About 15L for 50 laps, or 95 miles. So 28mpg..normal road use.... I am impressed with the 110 up Avon Rise (I will not tell you how fast the Ultima is at that point). As for the limit on the +8 it is not scary at all when it starts to to get there. The grip, balance and handling is much better than many would think. If you want to look at improving your speed round Castle Combe there is some good tuition here: https://www.merlinmotorsport.co.uk/pages/merlinmotorsport-videos#122307605You should be taking the modern car line through Avon Rise and Quarry. You will pull 20/30 meters out of most track day drivers just round Quarry. I try to be aiming for the traffic lights before the top of Avon Rise and have the steering wheel straight over the top so the car goes light with no steering input. Let the car load up again and hard on the brakes. Peter you should come to Silverstone next time we go as the track is wider and it has modern safety, Castle Combe the walls are hard and with very little run off which is not the best place to explore the car. Or do a "Car Limits" day at North Weald.
Morgan +8 Morgan Club Sport
Posts: 7,363 |
Only just caught this- hope it's fixed quickly... +1 and does not prove too expensive! 👍
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
