6 members (Ian B, IcePack, AlanB, verysideways, Lance, Graham, G4FUJ), 145 guests, and 112 robots.
+8Rich 101
John V6 66
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,920
Posts838,283
Smed., Spanner Juggler
Page 3 of 3 1 2 3
Originally Posted By WaveyD
I've noticed on my Plus 4 that the two bonnet halves slide forward over time, bumping up against the cowl. This has resulted in some paint rubbing on the cowl and a slight bend on the front upper corner of the driver's side bonnet panel.
I can move the panels back so that the gaps are all nice and equal, but I can't see a way to keep that position and on the next run they silently slide forward again. The brackets for the center bonnet bar look correct (though I'm new to Morgans).
Any tricks to keeping the panels in place? Could the bonnet bar brackets be worn and in need of replacement?
Thanks
dave
I bought a DHC that had spacers cut from the brass fixture that holds the bonnet. Like cutting a loaf of bread. BTW: I see You are from Santa Monica. Derek Wilburn knows this drill. If You don't know Derek, ask Dennis Glavis the So. Cal. Morgan Dealer.
Button
Thanks
dave
Yes! But the cowl probably could be pushed back. There is a lot of fiddle in the front sheet metal of a Morgan.
Button
Page 3 of 3 1 2 3
