2 members (TalkMorgan, teknome), 394 guests, and 111 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,760
I have just bought an Urban Cooling Kit to fit to my 2012 Car.
Does anyone have a copy of the update file?
550-0158 Rev C Morgan 3 Wheeler EU Production Cal 3 USB Mod X121.box
I have been sent a copy of Rev B for EU cars, but i'm concerned that the Rev C contains updated firmware.
The top cover for the fan is matt ABS/plastic and I had thought of painting it, any recommendations?
Archie, you might want to consider hooking the kit up with a relay to a switch on the dash instead of disturbing the ECU. Some have had a problem with reflashing the ECU. But then you may be far ahead of me in the electronics department
Hi
I have a 2012 car and I recently self installed the Urban kit .
I flashed the ECU with the box file which has the fan controlling software update.
I can't get a screen shot onto here, so I will type what the Comment view is for the file
Name: 550-0158 Rev B Morgan 3 Wheeler EU Production Cal 3 USB Mod
Comment:
550-0158 Rev B Morgan 3 Wheeler Production Cal 3: X121 , EU Calibration, 548 intake 545 exhaust CR Cams, SBTB, adjustable TPS, Morgan Air Cleaner, True Dual Exhaust, Closed loop, Knock control, fan control. For use with code version 55-5069ba984. Release date: October 2013
Cal 2: Ignition timing update to reduce knock at high load.
Cal 3: Fan control added
I also have the flashing Instructions which which contrarily state that the EU file is Rev C !!!!
If you get the Rev C , could you please let me know what the comments field says . I too would like to know what changes were made and if they would apply to the early models.
As I said before, no issues running with Rev B
Nigel
Screenshot
Rev B Cal 3 comment field by nigel smith, on Flickr
