8 members (andymog1, cerealsurfer, Graham, G4FUJ, Paul F, SailingTom2, BertR, Image, ChrisConvertible), 222 guests, and 38 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,123
Page 2 of 5 1 2 3 4 5
Jules Offline OP
Thank you again all of you for the feedback.
Beyond warranty concerns (which would not apply in my case), there's the question of the insurrance that I've overlooked.
If you don't mind, I will edit my post above to make it easy from a summary perspective.
Originally Posted By Jules
Thanks you all for the additional information!
G56 "sounds" like the best option for me
If noise is likely to be an issue then G56 is the right decision. However, at speed there is no noticeable increase in noise (to the occupants) even with the MMC version and long journeys are no more tiring than with a standard exhaust.
I agree with all the comments above except to say this. When the inevitable crowd gathers and you press that start button, the MMC Stage 1 doesn't disappoint.
Do my neighbours sit bolt upright in bed when I leave early on a Sunday morning. Probably.
Robert
Jules Offline OP
hhummmm... this is a tough decision!
In true Belgian style, I could make a nice compromise, since there are two cylinders, one pipe of each ;-)
Robert
Garage 28 and MMC 0.5 won't work very well.
Tim
I am very happy with the G56 system and standard ECU on my M3W. It's a big improvement over the standard system but probably very similar to the Morgan Stage 1 in performance if not noise. It doesn't disappoint on start up either, a nice deep rumble. The insurance (G&W) is unchanged.
And to complete the picture, I cannot fault my G56 with their own ECU, fettled perfectly by the very helpful Dan @Krazy Horse. So much smoother and more responsive than stock and although I've not driven an MMC-S1 car, nothing makes me think I'm missing that 'factory' something.
I'm also with Headley and they were perfectly happy with the update. I suspect there's no such thing as a standard M3W anymore - not even those that leave the factory doors - as they all break in one way or another and are fixed with a range of differing solutions.....
Looking at both, the G56 is better engineered too. The MMC version is a bit of a faff to fit but it can be done without modification and spacers (eventually). After all, the factory manage it.
At one point Williams were advertising a Garge56 (sic) for under £1300 on their website. Maybe a Chinese copy laugh2 They took two weeks to answer my emails so I gave up. (They have now corrected it) Better to deal direct with G56 I suspect.
Robert
Jules Offline OP
Indeed Robert, I've exchanged a few mails with Garage 56.
They can in fact deliver the kit to your "own" Morgan garage, which I find very handy.
For those of you who have used the G56 ECU:
- How difficult was the installation?
- Have you seen a noticeable decrease in average mpg or does this mainly seem to provide extra fuel (hp) at the highest rpm ranges?
- The ECU isn't cheap. Do you think it's worth the cost?
Thanks.
