Topics49,909
Posts838,126
Posts: 561 |
My S4 Aero has developed a new problem - at night the headlights (full & dip) intermittently go out, then come back on. The duration is a second or two - irritating in town but potentially very interesting in the country!  Anyone come across this before - could it be as simple as a faulty switch?
New joints for old!
Posts: 3,841 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,841 Likes: 11 |
That's a worrying development. Have you spoken to the factory? Maybe the factory should start providing these.
Slowly going green
Posts: 7,935 Likes: 133
Posts: 7,935 Likes: 133 |
Have you noticed if they do it on smooth roads?
From the sound of it, I'd say it was a loose wire but if so, it should be more pronounced on uneven surfaces.
Another test would be to leave the car running, with the lights on, and keep it stationary. If they still flicker, I'd put it down to an issue with the ECU or one of the other control modules. If they don't flicker, it would seem to support the loose connection / wire theory.
Posts: 561 |
Smooth roads around London.........!!!!  Didn't seem to make much difference, but have just rebooted the ECU and the problem seems to have gone when I went for a test drive last night. Maybe it was  Next week will be visiting BHM for a diagnostic check - will keep you posted
New joints for old!
Posts: 7,363 |
Next week will be visiting BHM for a diagnostic check - will keep you posted I think a trip to the works is called for Bill, no doubt Mark (Baldwin) will sort your residual problems out tout suite!  Best wishes Brian
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
I think a trip to the works is called for Bill, no doubt Mark (Baldwin) will sort your residual problems out tout suite!  Certainly did mine, after the extended stay at a nameless dealer for the problem to re-emerge on the way home.
Slowly going green
NGUNS!! Part of the Furniture
Posts: 4,564 |
My S4 Aero has developed a new problem - at night the headlights (full & dip) intermittently go out, then come back on. The duration is a second or two - irritating in town but potentially very interesting in the country!  Anyone come across this before - could it be as simple as a faulty switch? When this happens Bill, are you by any chance turning the rotating knob to the right of the steering wheel? If so, I think I know the problem
Cheers
BtG
Posts: 105 |
My S4 Aero has developed a new problem - at night the headlights (full & dip) intermittently go out, then come back on. The duration is a second or two - irritating in town but potentially very interesting in the country!  Anyone come across this before - could it be as simple as a faulty switch? When this happens Bill, are you by any chance turning the rotating knob to the right of the steering wheel? If so, I think I know the problem I have had this exact problem: headlights flicker when adjusting the dashboard brightness control. When you say you know the problem do you mean you've experienced the problem or that you know the cause/solution? David
Posts: 4,564 |
My S4 Aero has developed a new problem - at night the headlights (full & dip) intermittently go out, then come back on. The duration is a second or two - irritating in town but potentially very interesting in the country!  Anyone come across this before - could it be as simple as a faulty switch? When this happens Bill, are you by any chance turning the rotating knob to the right of the steering wheel? If so, I think I know the problem I have had this exact problem: headlights flicker when adjusting the dashboard brightness control. When you say you know the problem do you mean you've experienced the problem or that you know the cause/solution? David Sorry David, tongue in cheek, I was referring to the lights on/off switch
Cheers
BtG
Posts: 561 |
Also noted similar effect when I close my eyes momentarily........
New joints for old!
