5 members (Clipper, banbury, Luddite, Strathaven, ITP), 245 guests, and 25 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,109
My S4 Aero has developed a new problem - at night the headlights (full & dip) intermittently go out, then come back on. The duration is a second or two - irritating in town but potentially very interesting in the country! scared
Anyone come across this before - could it be as simple as a faulty switch? read
New joints for old!
le Asbo du Bling
le Asbo du Bling
That's a worrying development. Have you spoken to the factory?
Maybe the factory should start providing these.
Slowly going green
Have you noticed if they do it on smooth roads?
From the sound of it, I'd say it was a loose wire but if so, it should be more pronounced on uneven surfaces.
Another test would be to leave the car running, with the lights on, and keep it stationary. If they still flicker, I'd put it down to an issue with the ECU or one of the other control modules. If they don't flicker, it would seem to support the loose connection / wire theory.
Smooth roads around London.........!!!! rofl
Didn't seem to make much difference, but have just rebooted the ECU and the problem seems to have gone when I went for a test drive last night. Maybe it was carrot
Next week will be visiting BHM for a diagnostic check - will keep you posted sherlock
New joints for old!
I think a trip to the works is called for Bill, no doubt Mark (Baldwin) will sort your residual problems out tout suite! cheers flag
Best wishes
Brian
Brian
2014 Morgan SP1 (Rocket Red)
le Asbo du Bling
le Asbo du Bling
Certainly did mine, after the extended stay at a nameless dealer for the problem to re-emerge on the way home.
Slowly going green
NGUNS!!
NGUNS!!
When this happens Bill, are you by any chance turning the rotating knob to the right of the steering wheel? If so, I think I know the problem smile
Cheers
BtG
I have had this exact problem: headlights flicker when adjusting the dashboard brightness control. When you say you know the problem do you mean you've experienced the problem or that you know the cause/solution?
David
NGUNS!!
NGUNS!!
David
Sorry David, tongue in cheek, I was referring to the lights on/off switch hide
Cheers
BtG
Also noted similar effect when I close my eyes momentarily........ hide
New joints for old!
