7 members (RickyH, MartO, Sir Percival, JohnHarris, Rastus, Laurens, RichardV6), 342 guests, and 30 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,099
NGUNS!!
NGUNS!!
Originally Posted By orthodoc
Also noted similar effect when I close my eyes momentarily........ hide
laugh2
Cheers
BtG
My S4 Aero has developed a new problem - at night the headlights (full & dip) intermittently go out, then come back on. The duration is a second or two - irritating in town but potentially very interesting in the country! scared
Anyone come across this before - could it be as simple as a faulty switch? read
When this happens Bill, are you by any chance turning the rotating knob to the right of the steering wheel? If so, I think I know the problem smile
I have had this exact problem: headlights flicker when adjusting the dashboard brightness control. When you say you know the problem do you mean you've experienced the problem or that you know the cause/solution?
David
Sorry David, tongue in cheek, I was referring to the lights on/off switch hide
Not to worry. Maybe I have the momentary eye closing problem! blush
Update as promised! sherlock
Went down to BHM where Keith (fount of all Morgan Mysteries) notworthy found that there were loose leads in a connecting block by the light switch. Juggling the connector extinguished both dip & full beam!
Coincidentally two leads then continued to the tyre sensor which might explain that instrument's intermittent fault. happy3
The logic certainly fits so we will wait & see.
Can't praise BHM too highly thumbs
New joints for old!
