10 members (vincentvg, RubyMog95, Moggo, John Winn, Hamwich, Jock, simon8201, flyfisher, IcePack, JohnHarris), 142 guests, and 35 robots.
+8Rich 91
John V6 49
Posts837,976
#469545 29/08/17 10:48 PM
As many of you have done, I recently replaced the stock headlamps w/LED lamps. A very helpful post, which I am grateful for and followed for instructions, discussed removing the bulb in the small running light ("side light" in UK/Morgan vernacular) and wrapping in tape. On the driver's side of my M3W, this resulted in inadvertent contact between the two sides of the running light connector, which caused a short. How would you know? Because the same circuit and fuse are responsible for the driver's side taillight (again, "side light" on the Morgan fuse box) and I was only getting light on the passenger side taillight. 5A fuse drivers side 3rd from left, rear row is in the circuit.
Fix: leave the bulb in the connector; or cut the wires and separate.
BTW, this is not a slam in any way on the original poster, without whose advice I may not have found the wonderful Speaker lamps. Kudos to him. Drive on!
Aka Joejoe
Surprised the sidelight circuit was live!
Can you link to the post in question please?
kirkusblog.com
1952 Ford 8N
It's a very good detailed write-up:
http://www.talkmorgan.com/ubbthreads.php/topics/457525/1
Aka Joejoe
4 years old though - the newer Trucklite might be worth considering...
