7 members (Barkbark, Moggo, JMcL, Tony Quinn, +8Rich, TBM, BigLes),
295
Posts837,985
Posts: 78 |
Good morning gentlemen, and ladies, I need some help I have a 2010 Royal Ivory Roadster, im located in Dubai, I need some advice on best product for stone chip repair, I will obviously have to buy it from the UK but which product? where from? and how can I be sure of a good colour match? Thanks in advance.
Grissly
Volvo XC60 x2 Volvo C30 2010 Roadster 2001 Triumph Thunderbird
Posts: 237 Likes: 1
Posts: 237 Likes: 1 |
Hi Grissly,
As Glenn has said Chipex is the place to go & the one I have used. Colour match is excellent & I assume your 2010 Royal Ivory is the same as my 2015 Royal Ivory but please check first!!! Colour code on my 4/4 is on the build plate under the bonnet.
Dave
2015 4/4 Royal Ivory 2019 Fiat 500C 2019 Volvo V40 T3R
Posts: 2,583 |
+1 a great product and a good result.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Ditto, my car is a Royal Ivory and Chipex are great.
Posts: 990 |
Yes - Chipex is the way to go. they have the Morgan colour codes on their website and the match is brilliant. They are helpful too. Read the instructions you get with the kit! Its not hard to use but dries faster than you'd imagine - which will be really quick in Dubai i guess!
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
I have used Chipex and the colour match was very good. That said it requires real skill to get the repair level with the surrounding paint or the repair remains visible.
maybe one of the dent repair chaps using a chipex kit - this is an area where skills and experience are worth more than intelligence and effort.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
I have used Chipex and the colour match was very good. That said it requires real skill to get the repair level with the surrounding paint or the repair remains visible. You wouldn't think of it to look at my poxy old wings, spattered as they are with stone chips, cracked filler, and general nastiness, but I have got excellent results in the past with Chipex kits by adding a wet-sanding step using 1200 and 2000grit wet and dry, followed by some vigorous polishing. As Howard says, it's flippin' difficult to get the repair level the way the instructions tell you, but add in a judicious bit of rubbing down after you've filled the chip and it becomes a lot easier to get a great looking result.
Posts: 27 |
I'm searching for a recent post defining rosso corsa paint codes pre and post 1997 but without success. Can anyone point me in the right direction please? Many thanks. Brian
