3 members (+8Rich, 1854sailor, DaveK), 259 guests, and 28 robots.
+8Rich 100
John V6 57
Topics49,911
Posts838,150
Georgetoad, woolfie
Page 1 of 4 1 2 3 4
#471610 08/09/17 01:25 PM
docdav Offline OP
The Headlamps on AR Plus 4 looks fantastic.
Can you change standard Lucas on a 4/4 to LED type?
Is it "plug and play"?
Where to buy?
Kind regards and greetings from rainy Denmark
Michael
Michael, e bay have several LED lights that will fit a Mog.
I have standard h4 bulb plus a half circle of "side light LEDs.
http://www.ebay.co.uk/usr/powerful_uk_ltd?_trksid=p2060353.m2749.l2754
LED head lights need cooling space & I am not sure that LED bulbs will fit into the headlamp bowl on a Mog as they are longer.
Hi John
The link you supply does give the supplier but not the actual part you suggest, would you please send the part link
Triumph Herald 1969 13/60
Morris 1970
kirkusblog.com
1952 Ford 8N
Rob
Try this link , there are several other suppliers out there , so Google and check some of them:
https://www.britpart.com/parts/lighting/light-conversion-and-upgrades/lynx-eye/da6282/
Andy G
1999 +8 , Indigo Blue.
Jw Speaker are the ones Morgan use.
Beware the knockoffs.
kirkusblog.com
1952 Ford 8N
kirkusblog.com
1952 Ford 8N
Originally Posted By BuyBritish
Hi John
http://www.powerfuluk.com/vehicles/other...-style-rhd.html
Give them a call as they make one for Morgans which I think is this one.
Be careful with replacement headlights as they can cause an MOT fail if you have not met all the regulations. For example: I am lucky to be very friendly with my local MOT shop, who I have used for over 15 years. I had replaced the original halogen bulbs on my rally 911 RSR with HID mechanical dipping bulbs. Apparently these are only legal if you either have self levelling rear suspension (my Ohlins rear struts are self levelling) or like my later 997, electrically self adjusting level headlights AND head light washers. They let me get away with it, as it is only used for rallying and nearly all road mileage is on a trailer.
Wilson
docdav Offline OP
I thank you all.
Which model will fit my car?
The 8700 doesnt look like the ones on AR Plus 4?
Michael
Page 1 of 4 1 2 3 4
