0 members (),
241
47
Topics49,911
Posts838,148
Posts: 33 |
The Headlamps on AR Plus 4 looks fantastic. Can you change standard Lucas on a 4/4 to LED type? Is it "plug and play"? Where to buy?
Kind regards and greetings from rainy Denmark Michael
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Michael, e bay have several LED lights that will fit a Mog. I have standard h4 bulb plus a half circle of "side light LEDs. http://www.ebay.co.uk/usr/powerful_uk_ltd?_trksid=p2060353.m2749.l2754LED head lights need cooling space & I am not sure that LED bulbs will fit into the headlamp bowl on a Mog as they are longer.
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Hi John
The link you supply does give the supplier but not the actual part you suggest, would you please send the part link
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 2,539 |
Posts: 2,539 |
Jw Speaker are the ones Morgan use. Beware the knockoffs.
Posts: 2,539 |
Hi John
The link you supply does give the supplier but not the actual part you suggest, would you please send the part link http://www.powerfuluk.com/vehicles/other...-style-rhd.htmlGive them a call as they make one for Morgans which I think is this one.
Posts: 580 Likes: 2
Posts: 580 Likes: 2 |
Be careful with replacement headlights as they can cause an MOT fail if you have not met all the regulations. For example: I am lucky to be very friendly with my local MOT shop, who I have used for over 15 years. I had replaced the original halogen bulbs on my rally 911 RSR with HID mechanical dipping bulbs. Apparently these are only legal if you either have self levelling rear suspension (my Ohlins rear struts are self levelling) or like my later 997, electrically self adjusting level headlights AND head light washers. They let me get away with it, as it is only used for rallying and nearly all road mileage is on a trailer.
Wilson
Posts: 33 |
I thank you all. Which model will fit my car? The 8700 doesnt look like the ones on AR Plus 4?
Michael
