5 members (Carbuilder, Davetherave, RichardV6, IcePack, bmgermany), 258 guests, and 43 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,043
Has anyone got any tips on replacing a diff seal. Use a impact gun to remove the nut? What torque do you re-tighten the nut to?
Martin R
For +8s, the axle is a 7HA
Salisbury quote 95-105 ft-lbs for the early style 7HA axles (I.e without crush sleeve).
For the later style 7HA axle, the crush sleeve was designed as a single use with the torque on the nut setting the pinion preload. Torque setting ??
The work round is to mark the nut & the pinion with centre pops or a line and count the number of turns and flats when removing the nut - for reassembly - wind the pinion nut back on with the same number of turns and flats. As you're unlikely to be able to count this when using an impact gun it's use will not be ideal.
I changed the diff seal on my 1972 4/4 a few months ago so can offer these tips from experience:
There are a number of different pinion seals, make sure you get the right one based on year. As bad luck would have it my 4/4 had the most expensive Timken seal!
As I was unsure about the torque figure, I made a tool up to lock the pinion flange, which was nothing more than a 5ft length of 2" x 1" box section, bolted to two opposing propshaft bolt holes and relieved to allow clearance for a socket on the pinion nut.
I marked the pinion and the nut with some Tippex with a volunteer holding the locking tool,I used my torque wrench going up in stages until I felt the nut move very slightly which was 139 ft lb
You will probably need some sort of puller to remove the flange, a three leg puller is the best with a small block of alloy or brass to protect the pinion shaft threads
Unless you are very very lucky the seal will come out in pieces. This is probably the most time consuming part of the job.
Check for wear to the part of the pinion flange where it engages with the seal, there should not be any. If there is, you are in trouble as the seal won't er seal! Give the flange a nice coating of gear oil.
Give the outside of the seal a nice coating of RTV compound and install it, make sure it goes in square, make a proper fitting mandrel up if possible.
Refit the pinion flange and replace the nut, a I used a bit of medium grade Locite on the nut but that is due to personal preference. Re-torque to the figure you obtained when removing the nut.
Check the breather hole on the axle is clear and refill with your favourite lubricant.
Hope this helps
Arwyn
