2 members (JMcL, MartO), 316 guests, and 37 robots.
+8Rich 95
John V6 52
Posts838,016
rockabilly john
Originally Posted By Rev 4K
has anyone managed to tame the side screens flexing outwards using magnets?
I find the problem particularly great when encountering a cross wind at motorway speeds.
My Roadster came factory-fitted with magnets and they weren't much use. They would pull off over time and regular re-gluing was needed. They would also pop out over any bump in the road.
My +8 came with the U-shaped rubber channels and these are really very good. Far better than the magnets.
+8 4.8
Folks -- I tried the magnet route with Neodymium magnets and it was only partially successful.
The total success was achieved by stitching some Industrial class velcro to the hood Flapfront and sticking a bit of the other side(Hook side) to the top front of the windscreen pillar -- this has two benefits --1- it stops the flap blowing outwards and thus allowing rain in at the corner of the hood and 2- it holds the sidescreens in at speed.
Why the factory doesnt do this as standard I dont know -- I even proposed a design for the hood front to eliminate the problem, sent it to the factory and they promised to sort it out the following October -- that was 3 years ago and the hoods are still as they were when I was in the factory last!!
The Velcro DOES sort out the problem and I found it way better than magnets
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Rev 4K Offline OP
Thanks Robbie. i think i will give the velcro approach a good coat of looking at.
2004 Silver Roadster S1
Originally Posted By Nevbag
I have posted three pics of screens in the 'Classic Morgan' category of TM's gallery thing ( sorry can't remember proper name, it's an age thing).
Nev.
Hi Nev.
Once you have your photo in tm-img.com you can post it directly into a post using the embed codes. Check out the Instructions for use
When you copy the embed "Full image" "BBCode" for one of your photos you get:
Code:
[img]http://tm-img.com/images/2017/12/09/DSC_0748e06c069c8f3d35b3.jpg[/img]
Which, when pasted in your text will give this result:
I retro fitted the U channels. They are great.
So did I but I fitted them on top of the original neoprene strip so that they are flush with the outer surface of the windscreen pillar. Apparently on some cars there is not enough space; on mine the driver's sid is tight and I loosened all the sidescreen screws and pushed the sidescreen back as far as possible.
