1 members (Hamwich), 348 guests, and 40 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Page 7 of 13 1 2 5 6 7 8 9 12 13
Originally Posted By Hamwich
Tracing the outline of the old wing onto cardboard and then cutting out the shape to make a template to trace it onto the new wing is an easy task.
But: the challenge is where to tape the template onto the new wing? Not only is the new wing wider than the old, but I also want to adjust the finished width to add in an extra 6mm or so.
So Button's cunning plan of establishing a datum line down the wing is a good one. I can then work off that to establish a reference from which I can displace the template by a consistent amount.
The last challenge is to ensure that the datum line is in the same relative position on both wings.
That's where Simon's recommendation of using the 3D printer to make a jig comes in.
Here's the plan:
1. Print out a simple pantograph that holds a pen at an adjustable distance from a base edge
2. Put a stripe of masking tape down the old wing where I want the datum line to go
3. Run the pantograph base down the outer edge of the wing, marking the datum line along the masking tape at a fixed distance from the outer edge.
3. Tape a strip of heavyweight paper with the edge aligned to the datum line on the old wing
4. Trace out the inner edge of the old wing onto the paper
6. Cut along the profile line to provide a template
7. Run the pantograph along the new wing to replicate datum line on the old wing
8. Adjust the pantograph to add the extra width
I want and run another datum line down the new wing
9. Use the new datum line as a base line for the template and transfer the required profile to the new wing
10. Take my trusty disc cutter and trim off the unwanted bit of wing
Hopefully I won't require step 11
11. Ring up Sid Watson and ask him to make me another wing smile
More news at the weekend, I have to do some actual work for a few days...
Yes just as I thought. Sure glad I could help (oops).
Button
Hamwich Online Content OP
OP Online Content
Started the scary bit today, trimming the left wing. First step was to mark up and measure the old wing (on the right) so I could make some templates to transfer the profile to the new wing (on the left)
Then I added a safety margin and made a cut, offered up the wing, saw where it needed trimming , and tried again.
After 4 trial fits and trims, I'm nearly there, but I'm knackered and the batteries for the disc cutter are flat. So that'll do for today. Now for a late lunch and off to the pub!
Well done Tim!!
Looking good - awesome work!
Keep us posted on progress - but do not rush it!!
Neil
It's a good colour match...........
Great work. If you were closer I'd come over and watch........ cozychair
Well done.
2025 MG ZS EV aka Trigger
Great work.
laugh2
Me too
Great work Tim, looking good
heart in mouth time with that cutter,I bet - but well done Tim thumbs .
The results are looking superb; that gel coat finish looks indistinguishable from the paint.... sherlock
Bye the bye, your earlier post spurred me on to look at the 10.8/12 volt Bosch angle grinder.Needless to say,'looking' turned into purchasing innocent
I have to say, it's one of the best tools I have acquired in a long while; it's been put to good use several times already.
Thanks for the tip - but please,no more 'till after Christmas;the piggy bank is feeling very light.... doh
James
Mercedes EQC 400 AMG
Smart Brabus Convertible
Honda Monkey Z125
OP Online Content
I'm glad you're happy with it, James. I have the hammer drill, impact driver, and jigsaw as well as the angle grinder so far. Lovely bits of kit.
Good progress Tim.
Martin (Deano)
