5 members (sbarracl, RichardV6, Image, MartinB60, JMcL), 309 guests, and 39 robots.
+8Rich 91
John V6 49
Posts837,985
Deejay Offline OP
I have come across a data sheet once published by Newnes Motor Repair and Overhauling for the late 1930s 4/4. It has details such as firing order, Solex carb jetting,valve timing, ignition timing, tappet clearances, plug gaps, toe-in of front wheels, tyre and oil pressures, recommended lubes and battery capacity.
Anyone out there need any such info??
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I have a 1938 Series 1 4/4. It may be interesting to see what is being spec'd.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Deejay Offline OP
Hi Mark B
Firing: 1,3,4,2; Solex choke 30-23, main 115, compensating 210, pilot 60. Valves (set with 6thou clearances) Inlet open 10 BTDC, Close 50 ABDC, Exhaust open 50 BBDC, Close 10 ATDC. Ignition timing: contact points begin to open at TDC (shown for cylinders 1 or 4 when line on flywheel opposite hole in case) . Tappets (cold) inlet .006 inch, exhaust .010 inch. Plug gap .022 - .025; distributor gap .012 - .015; front wheel toe in 1/8 inch max. Oil pressure 40 psi; oil grade 50 in summer and 40 in winter (UK temperatures I guess) Battery 57 ah.
Front tyres 5.00-16 18psi or 4.50-17 21psi.
Hope you ind useful.
Doug
1958 Triton 650
Some good stuff. Do they indicate which engine. Standard Special or Coventry Climax??
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Deejay Offline OP
Cheers,
Sadly not. There are two columns on the sheet labelled 1939 and 1937-38 but no engine type. Details in both columns are identical! I think the Standard engine was introduced in 1939 but whether it would have same settings as CC engine is debatable?
Doug
1958 Triton 650
Makes sense. I suspect CC as you surmise.
Cheers,
Mark
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
I saw this thread a bit late. But if someone is interested I still have some pdfs for these cars. Instruction manual, lubrication chart, repair manual.
Send me a PM if interested.
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
very likely the engine is the coventry climax!
Triumph Herald 1969 13/60
Morris 1970
