6 members (Robbie, Ian Wegg, moggywills, MJF, KLASG, nestor59310), 183 guests, and 59 robots.
+8Rich 83
Luddite 50
Posts837,946
#497495 04/02/18 08:04 PM
Hi, I need a new water pump for my 1976 +8. Can anyone tell me where to get one and a part number. The one fitted is wrong, the engine was replaced some years ago and I'm trying to get bits sorted.
It's a bit confusing for me.....
1m016
rory kim #497506 04/02/18 08:45 PM
I purchased one recently from Rimmer
https://rimmerbros.com/Item--i-GRID800036
There are a few that fit your year, I think there is a differance with the 'nose' the bit that the pulley fits onto
While my +8 is a 3.9 the pump is as described for a 4.0 as mine has the serpentine belt
do you still have a 3.5 engine ?
Mike Smith
2007 +4
rory kim #497555 04/02/18 10:43 PM
OEM water pumps have a shorter nose, such that they will fit into the space available, they are specific to the +8 and not P6 or SD1 generic. Give Mr Rutter or your local/favourite Morgan dealer a call.
rory kim #497559 04/02/18 11:02 PM
Ok so it is a special water pump for a Morgan. A short nosed one on eBay is not the one..... The car has a old 3.5 litre engine in it.
1m016
rory kim #497576 05/02/18 06:28 AM
Hi rory kim.
If you look at the rover SD1 water pump then if its similar. You will probably have to cut the nose off it to fit the +8. This is what I did with my spare water pump, although it was a tough job to hacksaw it through as the centre seemed to be hardened steel. The original pump I removed and it was reconditioned with a new seal and bearings. This was done in Hamilton New Zealand so not much good to you. There must be somebody in the UK who reconditions the pumps
Doug from deep deep downunder.
rory kim #497913 06/02/18 09:42 PM
Thanks Doug, the problem is I do not have an original one....... I will have to buy a
New one from a morgan dealer I guess. Thanks for your help, enjoy your summer
It's -6 over in cold England brrrrrrr
1m016
rory kim #497925 06/02/18 10:32 PM
Ray Offline
Talk to Rimmer,they are very good.
rory kim #498137 08/02/18 08:24 AM
Had a similar issue when replacing the water pump on my 3.9 Plus 8.
Never realised so many different versions were fitted to the Rover V8.
Eventually identified the correct short nose pump as the same as fitted to the Triumph TR8 installation.
Bought one at a very sensible price from a TR8 specialist in Hertfordshire.
Getting the two long bolts, that penetrate the water jacket, out was A MISSION!
Have kept the original for... what? Just a born hoarder, I'm afraid.
rory kim #498207 08/02/18 06:03 PM
Thank you all, the main problem is that I don't have one to view and match up.
Some new ones on eBay are £98 ish and the ones on Melvyn Rutters web site are £200 ish so I don't know what to think.............
1m016
rory kim #498212 08/02/18 06:19 PM
Give me 'til tomorrow and I'll photograph my original for you.
