7 members (moggywills, Ian Wegg, Robbie, KLASG, nestor59310, JMcL, hugo), 172 guests, and 63 robots.
+8Rich 83
Luddite 50
Posts837,946
#498194 08/02/18 05:10 PM
I've got a Rover V8 engine with the code 47A04702B, capacity believed to be 3.9ltrs
From reading all the Rover V8 identification charts I can get my hands on, they seem to agree it was an engine originally supplied to Morgan. Thing is, NONE of these charts have any dates on when the block was produced (its essential for an upcoming IVA test)
I've written to the factory, but as yet have had no reply.
Any ideas?
thanks
Simon
Series 1 Aero 8
For what it's worth my 1992 registered 3.9 Plus 8 has the engine number 47A01026A.
I've no reason to think the engine is not the original one.
Hi Simon
Give John Eales at JE Developments a call.
There's not much he doesn't know about Rover V8's
01455 202909
Simon @ Sifab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Morgan fiited the 3.9 between june 1990 and 1997 after which the 4.6 was fitted. I book does not quote the switch over month.
Martin (Deano)
During that period the engine morphed in the 4.0 (still a 3.9) but with GEMS electronics rather than the "hotwire" fi system.
Mine is a 1999 3.9 with original engine 47A0707B. It seems a digit short but that's what is in the registration book.
My 3.9 starts with 47A289 and was in build at the end of 1994
Assuming they ran numerically it would put 47A04702B later
Mike Smith
2007 +4
deano #498219 08/02/18 07:26 PM
But the 3.9 was also available from 1997!!
From a recently produced book: grin2
June 1997 Dealer Notice:
"As it has not been possible to obtain the current Range Rover 4.6 litre engine, due to supply problems with Rover and because of the modifications required for installation, we have arranged for a special engine to be prepared.
This uses the current 3.9 litre engine, but built using the standard 4.6 litre block. This involves stripping a new engine, removing the block, specially modifying a 4.6 litre block to accept the front cover, and rebuilding the engine.
This produces a special unit using largely standard Rover parts. The distributor set-up is largely the same as 3.9, as is the camshaft and ECU. The block is cross bolted for strength. The crank, pistons and block are standard Range Rover 4.6".
DaveW #498221 08/02/18 07:39 PM
Does that mean it continued along side the 4.6 as an option?
Martin (Deano)
