5 members (Grumpy2, Pittsartist, jbk, +8Rich, BHV), 157 guests, and 46 robots.
+8Rich 80
Luddite 50
Posts837,937
Page 3 of 10 1 2 3 4 5 9 10
Chris99 #498729 11/02/18 08:33 PM
Same guy who showed when my chassis cracked. He left his feeler gauge. All part of the learning process.
Went for a run it was cold, now garaged.
Tim
Chris99 #498940 12/02/18 09:01 PM
i just got some yellow leads to match me Ohlin's . haven't got a car to fit them on!!! still at RTCC!!!!!
Chris99 #498985 13/02/18 08:37 AM
Originally Posted By Chris99
I've measured the leads:
55cm long
90 degree plug at the coil pack end. The internal connector has an inside diameter of 4mm and outside dia of 5mm. The rubber boot ID is 13mm
I couldn't see a manufacturer's name on the coil pack but it had #0313# printed on it.
The Spark plug end has an elbow cap for a 12mm spark plug,
I have a rough drawing but at the moment can't seem to upload it to TM so will add this later.
I would be interested in a set of Magnecor (red) leads if you still plan to have a set made for yours, given above info. I notice they don't have them listed for M3W just yet but maybe you could ask if they could add to their catalogue.
RichardV6 #499011 13/02/18 12:01 PM
[/quote]
I would be interested in a set of Magnecor (red) leads if you still plan to have a set made for yours, given above info. I notice they don't have them listed for M3W just yet but maybe you could ask if they could add to their catalogue. [/quote]
I would be interested as well , starting with a price.
Apologies in a rush and bungled the quote ! blush
nippymog #499015 13/02/18 12:20 PM
Chris99 Offline OP
I'm chasing for pricing and will let you know asap.
Red Leader drive
Chris99 #499166 14/02/18 09:42 AM
Chris99 Offline OP
I've just spoken to the chap at Magnecor and it turns out they supply MMC with the leads for the M3W.
He's going to price up a set of the KV85 (red) leads and let me know.
Red Leader drive
Chris99 #499246 14/02/18 07:06 PM
Good work Red Leader thumbs
Chris99 #499593 16/02/18 06:18 PM
I m interesting to
Chris99 #499781 17/02/18 09:10 PM
Also interested in a set Chris.
Chris99 #499787 17/02/18 10:01 PM
Chris99 Offline OP
They are going to be just under £45 a set inc P&P and VAT.
Phil at Magnecor is making my set up and will let me know a part number for both Red and Blue versions. You'll then be able to order directly.
They will have black plug caps as they don't make the "bent" caps in red or blue but should still look good.
Red Leader drive
