Topics49,921
Posts838,286
Posts: 16 |
I've been pondering the options to better use the under-panel space behind the seats on my 63 Plus4, and finally did something about it. I've seen the creations of others, and this is what I came up with. The original panel is fine with new carpet so the new storage tray simply sits below that, with the old panel sitting on top. Overall I lost 5/8" depth which is fine. 3/8" plywood with holes cut out for a pair of half-size catering trays. As the tray lips sit slightly proud, I cut a 1/4" ply panel to sit around the trays giving enough clearance for the tray lips and the sheet metal screws holding them in place. the additional slots are for the battery tender cable and seat belts. Total time, about 2 hours, total cost under $40 for wood and trays. Very happy. Photos via links. dave https://photos.app.goo.gl/Uk3u5zW8qxln6EY43https://photos.app.goo.gl/3BfCjrS1eWlkuJZc2https://photos.app.goo.gl/OXTG7ihULTl6FiTl2https://photos.app.goo.gl/XG5AD0l7ppW10UVU2
'63 Plus4
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Clever, great work. Thank you for sharing
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
That is a nice job. Much sturdier than my factory fitted plastic thing.
Roger 2011 Plus 4
Posts: 350 |
Thanks for sharing your project. I've been thinking about something similar for my 1959 DHC, and I like your solution.
1961 +4 Four seater
"Crude, but effective."
Posts: 1,943 |
Thanks for sharing your project. I've been thinking about something similar for my 1959 DHC, and I like your solution. I think I have a better design (Not My Work) for Your '59 DHC. It is a plywood box under the gas tank. You must remove the spare for access. Holds Side Windows plus Stuff.
Button
