5 members (+8Rich, Alan Patterson, Grumpy2, Pittsartist, jbk), 185 guests, and 56 robots.
+8Rich 80
Luddite 50
Posts837,937
Page 4 of 10 1 2 3 4 5 6 9 10
Dab of oppo #499788 17/02/18 10:05 PM
Chris99 Offline OP
Originally Posted By Dab of oppo
S & S service manual states .035-.045" withe a torque setting of 11-18ft/lbs and anti seize compound on the threads.
I checked mine today at .045" so closed them up to .040" middle limit.
Started in less than 1 revolution.
Its almost back together again now.
I put new NGK Iridium plugs in today with .040 gap which is also what NGK say.
Prior to changing it took 10 secs turning, 5 rest, 10 turning, 5 rest then fired after another 7-8 seconds.
With the new plugs it fired immediately.
Before I get too carried away I'll see how it starts first thing tomorrow morning.
Red Leader drive
Chris99 #501110 26/02/18 12:55 PM
Chris99 Offline OP
The new leads have arrived smile
Magnecor part number 2547 - Morgan 3 Wheeler 2.0 V-Twin cylinder
£32.09 plus p&p and VAT - total for me was £45.41
It may be a couple of weeks before I get to fit and test them.
Red Leader drive
Chris99 #501190 27/02/18 08:49 AM
Thanks for info Chris. Will be ordering some. Did Magnecor supply them to you direct as cannot see they normally do mail order?
ETA: just ordered some direct by mail order. Not in catalogue at the moment so dealers won't have them.
RichardV6 #501227 27/02/18 01:48 PM
Chris99 Offline OP
thumbs Richard.
Yes, order them direct. It's a new part number so won't be in the catalogue.
They should be able to do blue leads as well if you ask.
Red Leader drive
Chris99 #501238 27/02/18 03:47 PM
Are these thicker wires?
2017 M3W Sport Green
2Sharp #501296 27/02/18 08:24 PM
Check out here. As I understand it the kits mentioned by Chris employ the KV85 8.5mm cable.
Note Magnecor make the OE cables for MMC as well.
Chris99 #504480 19/03/18 07:14 PM
I bought them in blue
Tomorrow I install them
RichardV6 #504501 19/03/18 09:52 PM
Chris99 Offline OP
Yes, these are KV85.
Mine are fitted but due to holidays & snow I've not had a chance to drive with them yet.
Red Leader drive
Chris99 #504509 19/03/18 11:44 PM
Just started to install mine. There are four standoff cable ties holding cables to chassis tubes. If your careful the standoff parts can be re-used with normal cable ties.
There are also plastic P clips each side supporting leads as they come out of igniter box and which appear to be pop-rivetted to chassis cross tube. Will drill out rivets tomorrow and re-rivet P clips on new leads assuming they will accomodate the 8.5mm leads.
RichardV6 #504510 20/03/18 12:02 AM
The P clips don't fit the new leads well Richard. When I took the old leads off I found they were slightly chaffed from the cowl as it gets very close there. I would suggest you cable tie them a bit more outboard to give better clearance. Not driven with them yet either but it seems to start a bit quicker than before from cold.
