3 members (bmgermany, Piloto, John V6), 142 guests, and 40 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,153
Georgetoad, woolfie
Page 2 of 5 1 2 3 4 5
Originally Posted By +8Rich
I think it looks good under the Morgan script badge where you are holding it.
+1
BTW I would like to have a badge which only shows 4/4 on my 4/4. Is something like this available?
+1
I've never seen one Heinz, maybe Stewart spotted one on his badge hunt?
It's maybe worth PMing Hermen and Tcherek, if anyone will know it will be the pair of them.
Confirm 4/4 were / are available, try Melvyn Rutter or Factory ?
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Me again! Belmog show one as being available.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Here's the link Heinz.
http://www.belmog.com/index.php?route=product/product&product_id=537&search=4%2F4+badge
I imagined you wanted it in script though.
Bought a Roadster script rear badge with the intention of putting it on the back of the Morgan
I’m guessing they are quite a new addition to the Roadsters and weren’t put on 2008 cars
If anybody knows when they started to be fitted?
Anyway
I’m having second thoughts and can’t decide whether...
1. To fit it at all
2. Fit it under the existing Morgan script badge
3. Fit it on the left hand side
Any thoughts me learn-ned friends?
¿Can you take "Morgan" off and put "Roadster" in its place? I mean ¿It would be possible to switch script's places or "Morgan" is glued into place? I'm used to see cars with its brand's name on the left and the model's name on the right
Daniel
I'm not a Morgan owner...yet!
I think the two scripts on the same side look lovely & sit so well. But how would they fix..?
It’s either drill two holes and fix through with nuts or I grind off the threaded studs and stick with tape
If you use the double sided tape method you can always change your mind and easily remove it.
Martin (Deano)
Stewart,
on my 2006 S1 the Roadster badge is there on the LHS.
I think placing below the Morgan one would look good.
Are the bolt threads at the same distance apart on both of the badges?
The Morgan badge may have been added to Stewarts car by the previous owner.
