5 members (Alan Patterson, Grumpy2, Pittsartist, jbk, +8Rich), 147 guests, and 42 robots.
+8Rich 80
Luddite 50
Posts837,937
Page 2 of 10 1 2 3 4 9 10
Chris99 #498228 08/02/18 08:19 PM
I haven't taken them off yet - maybe in the next week or so - I'll post length dimensions once they're off kankeL
Mark H #498232 08/02/18 08:48 PM
that would be great! thanks!
kankeL #498276 09/02/18 09:24 AM
Chris99 Offline OP
I'm planning to get some Magnacor leads made up.
I'll need to get the measurements this weekend and will post them up.
Red Leader drive
Chris99 #498371 09/02/18 07:05 PM
What should the plug gap be? Today I went for a run cold 3c but dry. On return I washed the car & decided to check the plug gap to see if starting could be improved. The book says 0.97 to 1.07 mm but the ones removed were nearer 0.65 mm (0.025 inch). They are the standard Champion RA8HC copper tip. I opened them up & it would not start. I checked an old plug from last service & it was 0.65 so removed them & closed gap again but still wont start. There are sparks & it seems to be trying to catch after much turning over.
Perhaps my washing made something shorting out. Pushed in to the garage & battery on charge & I'll try again after thing had a chance to dry.
Tim
Chris99 #498434 10/02/18 09:48 AM
Chris99 Offline OP
I've measured the leads:
55cm long
90 degree plug at the coil pack end. The internal connector has an inside diameter of 4mm and outside dia of 5mm. The rubber boot ID is 13mm
I couldn't see a manufacturer's name on the coil pack but it had #0313# printed on it.
The Spark plug end has an elbow cap for a 12mm spark plug,
I have a rough drawing but at the moment can't seem to upload it to TM so will add this later.
Red Leader drive
Chris99 #498526 10/02/18 05:15 PM
S & S service manual states .035-.045" withe a torque setting of 11-18ft/lbs and anti seize compound on the threads.
I checked mine today at .045" so closed them up to .040" middle limit.
Started in less than 1 revolution.
Its almost back together again now.
Dab of oppo #498535 10/02/18 06:59 PM
Thanks Dab I,'ll try that tomorrow
Chris99 #498578 11/02/18 07:44 AM
Thanks
Chris99 #498667 11/02/18 03:54 PM
All sorted now & running again. Tried again with wider plug gaps & still would not start so called the AA. We tried swapping plugs & heating them & switch cleaner on the fuel injector connectors but still no go. He them put a meter on the the injector connectors & reckoned they were still damp despite my WD40 application. Dried off & now running again - joy!
Next wash I'll keep the hose away from the top of the engine.
Tim
TimG #498695 11/02/18 05:59 PM
Chris99 Offline OP
Good news Tim and it sounds like the AA chap knew what he was doing smile
Red Leader drive
