Topics49,911
Posts838,146
Posts: 72 |
Just wondering if a my 2006 4/4 with a 1.8 Duratec engine would have a OBD port lurking somewhere?
2006 4/4 70th Anniversary Edition 2004 3.2 Audi TT Quattro
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Yes. Poked up under the dash a little to the left of the steering wheel.
Roger 2011 Plus 4
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Yes, it will be up under the dash somewhere. You have to be able to reach it from the driver's seat.
Ah just remembered! There are a few 1.8 Duratecs cars out there that have had the OBD ECU diagnostic’s functionality disabled and the ECU locked by the factory in an attempt to solve certain issues. You will find out when you attach a scan tool and are unable to read anything if yours is one of those. I have fixed mine.
Roger 2011 Plus 4
Posts: 3,727 |
If you cant see it, or access it, you may need to drop the under tray as some are poked away so high during build that that is the only way to access it for the first time
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
O B D , O Bla Da, life goes on, bra La-la, how the life goes on
If only I could find it in my dash
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
Stewart, it is probably just hanging loose (oo errr, matron) somewhere behind the dash. Mine is to the left, just above the trannie tunnel ( behave yourself). 2002 Plus8 so other models may vary.
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
Stewart,
On my previous Roadster it was cable tied to the scuttle tube on the passenger side, cut the tie and you get about a foot of play in the cable
