12 members (sbarracl, James B W, Pipmac, Morganmike, DJC, IcePack, PaulV, Ian Wegg, Simon, AlyMatt, TalkMorgan, aerotaff),
224
36
Topics49,914
Posts838,179
Posts: 240 |
Hi Guys
The handbrake lever on my +4 is rattling like crazy, at around 3000rpm there is a constant loud rattle from the button rattling against the shaft.
I have wrapped a small piece of black tape around the shaft which has quietened it a little but not removed it fully.
Does anyone have a better fix\insight I haven't thought of?
Rylan
2015 Yellow +4
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Try some spray grease around the button.
I would also get underneath and check the fixings.
Posts: 14,009 |
Mine does the same. It’s definitely the release button rattling.
Does that button unscrew?
I think it does..... Of couse the innards might go boing.......
But a fine neoprene washer under the button would stop it rattling.
Posts: 14,009 |
Not sure Dave....I haven’t been brave enough to try as I don’t want to have to get under the car if it all goes pear shaped.
I think you NEED to do it as a successful author and Morgan authority 🤓😉
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Dare I say it, O.K. then, " They all do that Sir"
I think you NEED to do it as a successful author and Morgan authority 🤓😉 But mine don't rattle...........
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
Yes.
Ken
Posts: 240 |
The button does unscrew, but it can't be taken off, as far as I could tell, didn;t want to pull it and break something!
Will find some washers and report back
2015 Yellow +4
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Will find some washers and report back A stitch in time: Strongly advise you fix it pronto. A friend of mine had the whole lot disintegrate whilst ready to pull away at a set of traffic lights. Not easy to find the bits in the footwell and big queues behind him!
