Jay i have a 3.0l Roadster 2010 with full bumpers as yours, i want to fit the cibies as driving lights ie on with full beam, i have 2 questions, which brackets did you use for mounting and how did you wire them as driving lights?
thanks
Steve, on my previous Roadster I made some L shaped stainless brackets, they were then sandwiched through the main bumper bolt giving a horizontal to bolt down the spotlight bolt just above the bumper, I used some slender backed Stainless Spots from SVC, approx 5inch diam, the wire was even hidden down the core of the Spot bolt, very neat (apologies don't have photos)
I always wire through a relay, with a dedicated feed & fuse otherwise you are doubling the load on the existing wires (not advisable) and it's then easy to trigger the spots to only come on only with hi beam
