6 members (B3MOG, Wouter, John Winn, JohnHarris, Graham, G4FUJ, RedThree), 181 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
Arthur S Bell #531156 02/09/18 10:50 AM
JOB DONE! Once I got all of the trim out of the foot wells, I took the opportunity to scrape, prime & paint the metal areas where the factory powder paint had detached from the bulkhead (Pre-stainless bulkhead - so ‘thin’ mild steel), which was useful.
Next, cut and apply sticky-back insulating material on every visible surface...at this point, the foot wells resembled the inside of a space capsule - shiny silver foil everywhere.
Then it was a simple case of re-sticking the original carpet pieces (Of course, some of them were now too big, due to the addition of the 10mm insulation on each side’ so a little trimming was needed).
Road test with SWMBO proved successful. Gold stars all round!!!!!!
PS - whilst I had the gearbox tunnel cover off, I applied insulation to both sides; as well as making up a foam trim for the handbrake lever, reducing hot air leakage. And finally, stuffing more foam inside the gear-lever gaiter helps keep that leakage to a minimum, too.
SORRY - No photos!
ArthurSBell
N44MOG Rolls Royce Green +4
M22ASB Grey Renault Megane Cabriolet
M10SAB White Fiat 500
Arthur S Bell #531175 02/09/18 02:25 PM
A job well done.......... clap
Arthur S Bell #531242 02/09/18 06:12 PM
Thanks Dave!
A 2nd run out today & I’m even more pleased, as the sound-proofing in the cockpit really changes the tone of the ambient noice inside the car........
Can’t wait to experience a winter drive, when I’ll have the hard-top on.........BUT NOT YET🙏🤔
ArthurSBell
