10 members (Mogdavid, JoeSpeetjens, Plus Four Guy, jbk, Jock, RobS, simon8201, IcePack, MartinB60, PaulJ),
293
32
Posts837,973
Posts: 27,835 Likes: 758
Posts: 27,835 Likes: 758 |
Drive in reverse & hit the brakes to free them up.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
You didn't fail to release the handbrake fully by any chance?
1972 4/4 2 Seater
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
So I have taken the car to work - only 5 miles - and the slightly rubbing brake drum is slightly warmer - but not too hot to touch so there is no smell.
But, the smell is present - if only very slightly - and is under the bonnet at the back of the engine.
The clutch did not slip - I tried full throttle up some "hills" (it is Suffolk!) and no detectable slippage.
I did check the clutch fluid again and it looks decidedly dark (it was the brake fluid that was nice and clear) - I can change that easily I guess, but would it cause the issue?
Luckily the journey home will be much longer (!) so I can get it up to temperature and have a probe.
Sod's law at play here methinks - it's been driving perfectly all summer....
Posts: 513 Likes: 2
I did wonder about the handbrake so checked - I never put it on in the garage, and it was indeed fully off.
Posts: 516 Likes: 1
Posts: 516 Likes: 1 |
Maybe a daft question, but it's nothing to do with the heater motor is it?
When the heater motor burnt out on my subaru the electrical smell was similar to burning clutch/brakes. Don't know where the motor is on yours, but just a thought....
Malcolm T 1966 +4 1957 TR3 1963 TR4 1983 LR 110 1985 Robin Hood 2.0l
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
The other thing to check is the wiper motor. I had one burn out on an MG, same as the one fitted to my 4/4. Caused by the slip ring failing & it trying to run “ish”. It smelt like burnt biscuits.
Posts: 513 Likes: 2
Good thoughts - it's in that area that I can smell it...
Posts: 513 Likes: 2
Ok so a nice run of about 20 mins and there is a faint hot aroma. But nothing more. Brakes seem fine. I don't like these mysteries before a long trip... thanks for your help folks.
Ill drive it all week and see how we go
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Nick,
Mine would occasionally smell of burning after a long run, but not always, eventually decided it was road 'crap' burning off that was flicked up on the cat, hence not on every run out
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Sounds a bit like mechanical hypochondria. If the brakes arent hot to the touch after using the car then they arent binding. If the clutch doesnt slip in top gear full acceleration then no problem there. Only 9k miles - may well be just dust on the exhaust or catalyst if fitted. Give it a good thrashing for 20 or 30 miles and see if anything is wrong afterwards.
