0 members (),
231
43
Topics49,911
Posts838,148
Posts: 11 |
Hi, my dipped beam is not working on my 1995 +8. The main beam is fine. I'm assuming it's a relay or fuse, since both lights are not working. Any help appreciated.
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
As its common to both lights it could be the dipped beam contact broken in the switch?
1993 T16 +4 Lancia Blue.
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Are the dipped beams fused collectively or individually as on latest cars? If the former worth checking the fuse even if its only remaking the contact.
Posts: 11 |
I don't know if they are fused collectively, as there is no indication of which fuse is which. They are also a pain to get to, as they are tucked up under the dash. Anyway, I'll go through them all.
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Dim-dip unit, if it has not been disconnected by a previous owner. Pretty sure left and right headlights have separate fuses.
Posts: 934 Likes: 12
Posts: 934 Likes: 12 |
I had once the samen probleem and it was becauce the dim-dip switch came to close to the dashboard so there wasn't room enuf to dim .it hits the dasch before switching. On an 1988
Stefan
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
On 1980's cars there was no dim-dip module and no relays either so the steering column switches are very prone to burning their contacts leaving just the main beam working.
I don't know when they started fitting dim-dips and relays but this might be worth checking.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
In my 94 +8 I had the issue of the lights going out when I went to high beam. Wear in the switch over time had caused the contacts to not connect. Took the switch off cleaned the contacts and reset,all works fine now.
Posts: 11 |
Thanks, I've owned the car for 13 years and have had no problem up to now, so I'll look at the dim dip unit. Do you know if this is behind the dash ?
Reading posts above it doesn't sound like you have a dip unit or relay just the actual column dip switch. Suggest you fit a relay though after you have sorted the switching problem to reduce current through those ageing dip switch contacts.
