1 members (+8Rich),
231
Topics49,911
Posts838,151
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
How easy is it to remove the existing film as would like to replace ours. Has been on their since new.
Pull it off very very slowly, if it’s to hard to pull, then apply a little heat with a hair dryer...
Craig Jezz
Craig - would you mind providing some detail re. what type of PPF you use and a good supplier for same  I need to replace some of mine on the Aero and some of the prices quoted are on the silly side... James James, I purchased mine from bespoke privacy, they also do car window tints and leather repairs http://www.bespokeprivacy.com/
Craig Jezz
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Same problem with the Plus 8: I had the film replaced once, but the drivers side is now as scuffed as it was a couple of years ago.
I am tempted to take the film off, use it to make a template and then buy a length of the film and then replace the film every year..... My son Andy has experience in applying colour wrap and said that on a nice simple flat surface like the running board it will not be difficult.
I've also considered fitting tread rubbers, as we had on the Roadster.
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
Craig - would you mind providing some detail re. what type of PPF you use and a good supplier for same  I need to replace some of mine on the Aero and some of the prices quoted are on the silly side... James James, I purchased mine from bespoke privacy, they also do car window tints and leather repairs http://www.bespokeprivacy.com/ thanks Craig  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
I am tempted to take the film off, use it to make a template and then buy a length of the film and then replace the film every year..... Andy has experience in applying colour wrap and said that on a nice simple flat surface like the running board it will not be difficult.
I've also considered fitting tread rubbers, as we had on the Roadster. Hi Peter, once the film has been removed you will be unable to use it as a template, it will be destroyed. Andy is correct, flat areas like the running boards are much easier, the most tricky area is the front wings where it curves...
Craig Jezz
I've also considered fitting tread rubbers, as we had on the Roadster. Hi Peter, once the film has been removed you will be unable to use it as a template, it will be destroyed. Andy is correct, flat areas like the running boards are much easier, the most tricky area is the front wings where it curves... I thought it would come off as a single sheet! Obviously too simple! If I tape brown paper over the existing film it should be possible to use a soft pencil to mark out the edges, brass rubbing style. Then I can cut a paper template to use to mark out the film. Perhaps...
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
You can get some of the 3M Ventureshield on Amazon including the squeeze applicator if this helps. https://www.amazon.co.uk/VentureShield/b...n=VentureShield
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Or narrower running boards.....!!
