1 members (mph), 240 guests, and 33 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,148
Originally Posted By Tresco
How easy is it to remove the existing film as would like to replace ours. Has been on their since new.
Pull it off very very slowly, if it’s to hard to pull, then apply a little heat with a hair dryer...
Craig Jezz
Originally Posted By James B W
Craig
- would you mind providing some detail re. what type of PPF you use and a good supplier for same cheers
I need to replace some of mine on the Aero and some of the prices quoted are on the silly side...
James
James, I purchased mine from bespoke privacy, they also do car window tints and leather repairs
http://www.bespokeprivacy.com/
Craig Jezz
Formerly known as Aldermog
Same problem with the Plus 8: I had the film replaced once, but the drivers side is now as scuffed as it was a couple of years ago.
I am tempted to take the film off, use it to make a template and then buy a length of the film and then replace the film every year..... My son Andy has experience in applying colour wrap and said that on a nice simple flat surface like the running board it will not be difficult.
I've also considered fitting tread rubbers, as we had on the Roadster.
Craig
James
thanks Craig thumbs
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
I am tempted to take the film off, use it to make a template and then buy a length of the film and then replace the film every year..... Andy has experience in applying colour wrap and said that on a nice simple flat surface like the running board it will not be difficult.
Hi Peter, once the film has been removed you will be unable to use it as a template, it will be destroyed. Andy is correct, flat areas like the running boards are much easier, the most tricky area is the front wings where it curves...
Craig Jezz
I thought it would come off as a single sheet! Obviously too simple!
If I tape brown paper over the existing film it should be possible to use a soft pencil to mark out the edges, brass rubbing style. Then I can cut a paper template to use to mark out the film.
Perhaps...
Smile, it confuses them
You can get some of the 3M Ventureshield on Amazon including the squeeze applicator if this helps.
https://www.amazon.co.uk/VentureShield/b...n=VentureShield
Peter - Get longer legs!
Mark - No Longer driving
Or narrower running boards.....!!
