4 members (DCH, flyfisher, Alan Culpitt, sprinty), 324 guests, and 34 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
Page 2 of 5 1 2 3 4 5
Originally Posted By IvorMog
It's not just about bump and rebound. It's also about cornering and roll stiffness.
As you turn a corner the outside wheel loads up against the main spring and the unloading of the inside wheel is controlled by the rebound spring.
If you remove the rebound spring, there is nothing to control that unloading and that side of the car would just continue to lift until it runs out of space as the stub axle impacts the bottom crosshead bracket. This will give you no roll stiffness control and a horribly wallowy feel as you turn in.
If it's just a case of too short a rebound spring you will initially have very poor control of the roll stiffness until the inside jacks up a bit and then the stub axle contacts the short rebound spring to give you back a degree of very belated roll stiffness. Not as bad as no rebound spring but still a very wallowy turn in..
The solution is to use perfectly matched bump and rebound springs with the rebound spring just kissing the stub axle at rest.
As said before, read the Peter Ballard article and take time to assimilate it because it's not immediately obvious. Or at least it wasn't to me.
Very well put👍
And this is what the SSL kit gives you, with its adjustable spring seats.
Thanks all for comments. I can assure you I have no intention to remove the rebounds, but I do feel satisfaction with understanding the system and why the different components are there for. Seems like cutting (the lower end, I have been told) of the rebound is a good and cheap idea, so now I have to investigate how to get them off in the easiest way. The SSL kit would be nice, but a little pricey. The video recommended was very illustrative, and also Mr. Ballards article. I have read it before, at an earlier stage of my morbus morganensis. Now it has gotten more serious, and I understand more...
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Robbie,
There is another issue to consider regarding pre-load.
Over time and many miles the main spring may lose some of it's initial spring and length, so nullifying any initial pre load.
If you were to shorten the lower spring, then later on in the life of the assembly you might find that it becomes sloppy with free play and require the lower spring to be replaced.
Graham
Octogenarian - (83)
1.8 4/4 Ivory
Toyota Yar.
VolvoV70
Originally Posted By Moggo
Robbie,
Another reason to use the SSL kit with its adjustable spring seats , you can adjust the pre-load simply and quickly without dismantling the front suspension to renew springs.
Andy G
1999 +8 , Indigo Blue.
Robbie,
If this were to happen, would it not be possible just to insert a spacer of some sort below the rebound spring, until it just kisses the stub axle collar? Easier than buying a pair of new rebound springs with the hassle of installation etc surely?
CBY Offline
Depending on your car, the rebound spring may be free or not at static state. On my PLUS 4 2005 the rebound spring was not free.
In this case the stiffness of the suspension was very hard on small bump and after becomes soft on big bump, the opposite of a conventional suspension.
When the rebound spring is not free at static state, the gobal stiffness of the suspension is the sum of the both spring stiffness and determines the static height of the car. If you cut the rebound spring and get it free, the stiffness will be lower because only the main spring acts and you may get a lower static height.
I have installed the SSL front kit, in this case you can preload the main spring like in the conventional cars and get a free rebound spring. The suspension on small bumps is soft and increasing stiffness on bigger bump. You get quite a conventional suspension.
During the assembly with the SSL kit the global preload of the springs is lower, preload being adjusted and increased after assembly. Assembly is easier, main spring being free at the beginning.
Regards
2005 PLUS 4
Robbie,
This ^^^ is something I intend to look at when I fit Mulfab bearings to my Plus 4 over winter. I'll take some measurements when I dismantle of static loaded length and free spring length. There's an element of possible adjustment by using shims. One at the top of the kingpin so that the kingpin to bottom plate fixing is unaltered, and a U plate shim at the bottom to lower the rebound spring seating. In theory I reckon 5 or 6mm adjustment is possible, but I'll have to make the U spacers and look at the logistics.
I was talking to a Morgan Racer the other day. "Bill, I do not expect Morgan handling to conform to Me. I make every effort to get the best performance as it is, not as I wish it was. I have raced against too many other Marques to not know that Morgan handling is very good and I am competitive against them."
Button
Surely if you cut the lower spring if it's not free you might find the static height higher?
Nick
