0 members (), 317 guests, and 30 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
Page 5 of 5 1 2 3 4 5
Originally Posted By Moggo
Something else less well understood complicates this issue.
Gyroscopic Precession generates a force on spinning objects.
A sudden force on the axis of spin in our case will firstly cause the wheels to suddenly react by their tending to move in towards each other at the leading edge (toe-in). As the axle assembly moves the other way and against the lower rebound spring the opposite forces generate the opposite force so that the wheels then try to toe-out.
Any slight free play in the tie rod bushing will result in sudden ocillation between toe-in and toe-out.
For a motorcyclist the effect is noticed when pushing the handlebar (left or right): the bike lays over to the same side and NOT the other side as you might expect .
Very interesting. I've never considered that at all. Thanks for raising it.
Like I said: "It is complex". Also thank you for your explanation.
Button
CBY Offline
There is only a reaction if you try to change the angle of the rotation axle of the wheel. In a vertical translation of the stub axle on the kingpin there is no reaction... without play... theoreticaly.
The reaction is perpendicular to the movement (torque) applied.
Regards
2005 PLUS 4
